My samsung syncmaster t240 monitor has a green line going from the top of the screen to the bottom tried putting back to default settings no change tried changing resolution no change
  • 11,800 Answers
In that case the problem is in either the LCD screen itself (this is unfixable - th monitor has to be used as i or junked) or in the image processor - the motherboard must be replaced. Finding one that is cheap enough will be difficult , and a brand new part might cost more than the monitor is worth.
  My advice to you: use the monitor as is long enough to save the money for a new one.
Posted on Aug 06, 2010
Samsung T240 Problem
try check the cables and connection
Dec 17, 2013 | Samsung SyncMaster T240 Monitor
Why my monitor screens is color green
Your RGB settings has most likely been altered, resulting in some problems. Check your settings menu on the monitor itself and reset the settings to default. If that is not the problem, it's probably the computer's settings that has caused this change. You will need to go to the computers monitor settings and reset that to default to get back to normal colours.
Nov 04, 2012 | Samsung SyncMaster 915N 19" Flat Panel LCD...
The samsung t240 syncmaster when switched on shows Samsung Logo then displays for 2 seconds then goes dark. I can barely see some settings to change but trying to change these has no effect. When I switch...
Is this a laptop?
This a common problem for monitors, especially on laptops. This cause by the inverter board. The inverter boosts voltage to light the screen. When goes bad they go bad they often work for a few seconds. If you look closely you can see the screen but the voltage is not there to get brightness.
Dec 06, 2017 | Samsung SyncMaster T240 Monitor
Is there a new windows 7 driver for the Samsung Syncmaster T240 monitor? The problem I'm having is green flickering, where a green tint intermittantly comes over the monitor.
try reducing the refresh rate of the screen. I Hope the Driver for the moinotor is installed !!
But if it is intermittant..
Then Monitor may be going through normal ageing.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Samsung SyncMaster T240 Monitor
My samsung t240 screen turns black after 2 secs to an almost black screen, could it be a problem with the fuse as the monitor still has power??? plz help
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Samsung SyncMaster T240 Monitor
Samsung syncmaster t240 with thin colored stripes on display
Once you have stripes or lines in the screen then the only solution is to get the screen replaced but that would cost just as much or even more then getting a whole new monitor.
Aug 14, 2009 | Samsung SyncMaster T240 Monitor
Default settings
try using the default button on the top right side of the settings page
May 12, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
