There is a green line going from the top of the screen to the bottom
  • 4,737 Answers
Since you didn't mention the Your system type whether Laptop or Desktop, I can't assume myself on how to start troubleshooting. If it a laptop, please connect and external monitor and check if the same problem persists. If so, then the problem is with the graphics card, if not, then the problem is with the display of your laptop.
In case of Desktop, you better try the same monitor on another desktop, if there's similar problem, then the problem is with the Monitor, you better call for service or take it to a Service Center. It's also possible the graphics card is the culprit, so try with another monitor and you'll know what's the cause of the problem. If the same problem persists with the other monitor, you only option is to replace another graphics card.
(This isn't a solution, this is a clarification, I am awaiting your response so that we can start the actual steps on how to troubleshoot)
Thanks.
Posted on Jul 30, 2010
  • jameslen84 Jul 30, 2010
    sry its a syncmaster t240 samsung monitor thats getting the green line from the top of the screen to the bottom thought it might be the graphics card but it aint tried another monitor and it works fine
  • Lebanon Raingam
    Lebanon Raingam Jul 30, 2010
    Thanks, please try with another monitor. I would also suggest you to try the monitor on another system, switching the display cable will also be helpful (sometimes that small video cable is the faulty, so check it once again and make sure there's nothing wrong with it or physically damaged/broken/twisted pins).
    If it graphics card, the only option is to replace it or to install ad-on graphic card (if the existing video card is onboard).
    In case, it's the monitor, you have a chance to get it repaired, but I can't assure whether it would be successful, if the compartment which holds the Liquid (Crystal Liquid) is damaged, will be better to get a new one since repairing will cost you more than buying a new one. You can call Samsung in your area for additional information, but first contact the retailer/dealer where you bought it. They will give you instructions on how to contact or how to get it repaired from their Associate Service Center (if it's under warranty, they will promptly respond you and you'll get another replacement or will be repaired for you without any fee).
    Good luck.
    Thanks for using FixYa.
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Solid green line from top to bottom
screen is going bad in your monitor. Whenever you get lines in the monitor no mattery what color they are, that means the screen itself is going bad and in this case since no parts are available, the monitor needs to be replaced.
Feb 06, 2010 | ASUS VK222U 22" Monitor
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Scrolling Green color on screen
If the lines are like pin stripes going from left to right then you most likely have a defective green crt
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
PT 47 convergence IC's? box? both?
Always suspect the IC's first, digital convergence prblems are actually pretty rare IC's go everyday. I'd check partsore .com Generics usually work fine, they are probably STK392-110's but check to make sure.
Apr 16, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Open Questions:
How to Remove a Virus from Windows PC or Laptop - DataAlign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 17, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
