Question about Sony Cyber-Shot DSC-H1 Digital Camera
I WANTED BAY MEMORY STICK ,DONT HAVE??/ - Sony Cyber-Shot DSC-H1 Digital Camera
    President:
  • 1,194 Answers
Thanks for using Fixya.
Click Here to go to the website from where you can buy the memory stick for Sony Cyber-Shot DSC-H1 Digital camera.
There is one more website from which you can buy the memory card.
Good luck and have a nice day.
Posted on Jul 30, 2010
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
May 02, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
I need the memory stick number to my dcr-trv18 what memory stick do i need
Your camcorder uses the original Sony memory sticks in the following capacities:
4Mb, 8Mb, 16Mb, 32Mb, 64Mb and 128Mb. All but the 128Mb have been discontinued. You can look online for the 128Mb memory stick from many vendors. You may find the other ones from E-bay.
Apr 14, 2011 | Sony Handycam DCR-TRV18 Mini DV Digital...
Laptop freezes. Turn off. Wait. Turn on. 3 beeps. Small light on lid lock lights for about 12 secs then flashes 4 times. Cycle repeated.......No screen picture.
The most common cause of the '3 beep issue' is memory or RAM failure. Generally, only one memory stick goes bad (you only need one stick for your computer to work) so here's what you do:
Step 1: make sure the MacBook is off then remove ONLY 1 memory stick. After you remove it, place the battery back in the battery bay then try powering it on. If it works, you'll know that memory stick is failing and you can buy a new one fairly cheap.
Step 2: If step 1 didn't solve your issue, replace the 1st memory stick and pull out the 2nd. Replace your battery in the battery bay then power up. Usually one of the memory modules is bad. If neither step works for you, try getting a compatible memory stick that you know is working just so you can rule out both memory sticks being faulty. Here is my email adress: i_Patch,securepath@live.com Don't forget to vote if this helps you and good luck! Contact me if you have further questions.
Apr 18, 2010 | Computers & Internet
How to transfer music from a memory stick to a computer i dont know how to get the music i have saved on my memory stick back on to my computer
When you plugin your memory stick on your computer, browse on the folders that the music are saved and then if your eant to transfer it to your computer, right click on it an then copy. Now go to your desktop and then right click then paste. It will tranfer the music file frm the memory stick.
Apr 03, 2010 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Are the memory slots colour coded for a reason
mostly to signify bays.... ie.. bay 1 and bay 2, with each bay having a certain number of slots depending on motherboard. if you have more then one stick of memory you need to put one in bay 1 slot 1, and the other in bay 2 slot 1,... 4 sticks of memory (all the same gb) 2 sticks in bay 1, slot 1&2... 2 sticks in bay 2, slots 1&2.. and so forth
Feb 02, 2010 | HP Computers & Internet
I have problem with my memory stickproduo 8GB
Sounds like the memory stick is damaged, if you cant read it in a reader or the camera there is not much hope try a new memory stick to see if the problem reoccurs on the new one, if so then the camera itself is damaging the stick when it writes the file
Jun 23, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Recording
you can use an a/v to rca adapter cord to transfer from dv tape to vcr or dvd recorder. If you dont have the cord , you can get 1 cheap on e-bay, at walmart or radioshack.
Dec 18, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Sony digital dsc-f707 startup goes to "no memory stick"
Could be that the contacts on the camera are oxidised. Try cleaning the contacts with isopropyl alcohol and see if this helps. If not, it could indicate a circuitry problem. In this case, you'd probably be better off buying a new cam altogether!
Sep 28, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony Cyber-Shot DSC-H1 Digital Camera Logo
14 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
