Question about Konica Minolta bizhub 250 All-In-One Laser Printer
KONICA 7030 F-35-7 CODE
I HAVE A CUSTOMER WITH A KONICA 7030 F-35-7 CODE WHAT IS IT AND HOW DO YOU RESET IT. I AM A KYOCERA MITA TECHNICIAN THANK YOU
    Problem Solver:
  • 7 Answers
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Posted on May 21, 2008
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Feb 28, 2014 | Kyocera Mita Office Equipment & Supplies
How to re-set the error code C-6000 at my kyocera mita KM-2810
This error code is related to the fuser unit and should be investigated by a technician.
Mar 24, 2013 | Kyocera Mita Office Equipment & Supplies
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Nov 24, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
Kyocera Mita FS1010 fault
check your user guide... it will explain this error... or contact kyocera customer support...
Jun 25, 2009 | Kyocera Mita FS 1010 Laser Printer
I need to reset ID Code on Kyocera Mita KM-5530
The solution is easy! Push the Default Setting/Counter button on the top right side of the keyboard. Press the the Managment icon on the diplay. Enter 6-4-8-2 on the keyboard and select the Managment icon in the OFF position. Close all windows on the display and you should be ready to go.
Jun 17, 2009 | Kyocera Mita KM-4035 Printer
Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
May 26, 2009 | Kyocera KM-1505 Copier
Mita/Kyocera ai3010 and Konica 7022 Tarpon SPrings, fl
Kyocera Mita Ai 3010 works well only with OEM toner. Print System has no decent drivers for XP and forget about Vista. Doc feeder needs separation rollers every 15,000 feeds. I will replaced it if needs more than $250 in parts.
Feb 14, 2009 | Konica Minolta Office Equipment & Supplies
Kyocera
Kyocera Mita copier problem? tawag lang po sa number na ito 09483879552 or 09154815219
NAg aayos po kami kahit anong klase ng kyocera mita copierspara sa karagdagang detalye tawag lang po or
mag text sa mga number na nasa itaas ...salamat
Mar 07, 2008 | Kyocera KM-1505 Copier
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
1,180 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
