Question about Philips 42PF7320A 42 in. Plasma HDTV
I have a philips 42 inch plasma that requires a power supply board.... model number 42pf5331/10 serial number vn1b063801737.... adrienpatrickking@hotmail.com
  • Philips Master
  • 8,457 Answers
Tries websites like Shojimmy.com,Ebay.com to buy the whole refurbish power supply board.Can't find in catagories in data base in search.Ask help desk,send Email ask questions.Shopjimmy.com,Ebay.com have the most use refubish PCB for LCD,Plama tvs boards around the web.
Posted on Jul 30, 2010
I HAVE A 42" PHILIPS
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem....
Sep 26, 2011 | Philips 42PF9630A 42 in. Plasma Television
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
I have 42 plasma tv that makes a clicking noise then show 8 blinking red lights anyone now whats the problems my model # 42pf9431d/37
I don't have a fix, but the same thing happened to my Philips Plasma and the V repair man tells me that Philips no longer make the service pack which contained all the parts required to fix the TV. Basically Plasma screens run very hot and the components on the main board breakdown. So when the power supply goes so do many other parts. Philips used to supply all the bits in a service pack so it would seem that they (Philips) knew all about this inevitable fault from early production.
I am livid and if you paid what I paid then you are probably livid too. I expected it to breakdown one day but I never thought that it would be impossible to fix. I would never have bought a plasma if I knew it was considered to be a disposable item by the manufacturer. It could be worse, apparently Samsung don't support their TV's after 2 years.
I am phoning Philips in the morning and will post the results of that call if they have anything positive to say.
Dec 09, 2009 | Philips 42PF9630A 42 in. Plasma Television
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Philips 42PF7320A 42 in. Plasma HDTV Logo
423 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
