Question about HP LaserJet 2100 Printer
Printer Printing Crooked!
I have an old Laserjet 2100 that works great except for one small (major) problem....Everything that comes out of the printer is cockeyed! It doesn't appear to be a feed issue as there is no binding, and all of the edges of the paper are crisp and not damaged. Anyone have any idea what could be causing this, or how I can fix it?
Thanks in advance!!
    Scholar:
  • 87 Answers
Try printing from the multi purpose tray...do you get the same problem...if not you can narrow the problem down to the paper tray area...try changing main pickup roller and separation pad. If problem is present printing from either tray then the next place I would go is to the registration assembly (flapped unit that resides under the toner cartridge). The job of the part is to line the paper up before it feeds further in to the printing process. You could also do whats called a 1/2 test...put paper in the mp tray, do a print and when there is only about 2-3 inches of the paper sticking out the mp tray open the toner lid...lift out the toner cartridge and see if paper is skewed before entering the fuser. It really does sound like the registration assembly.
Inkworks
Posted on May 22, 2008
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
No printing
Well this issue must be related to the drivers of the printer, possibly incompatibility. Let's try to fix it with the easiest method.
First uninstall the driver after the printer is disconnected from the computer. Then run a registry cleaner (click here to download a freeware registry cleaner) to clear any unwanted registry files. You'll also need to clean the system using the feature with this application.
Now download this driver Hplaserjet 2100 windows vista32 (if your system is 32 bit) or hplaserjet 2100 windows vista64. Extract the files to a specific folder and follow the instructions as follows;
Click "Start" , select "Settings/control panel" and click the "Printers" folder.
Double-click "Add Printer".or click "File" on the menu and select "Add printer"
The "Add Printer wizard" will open. Select "My computer" then click "Next".
Select LPT1 (whether directly connected or networked) and click "Next".
Click "Have Disk".
Click "Browse".
The Locate file window will come up saying a: "is not accessible" . Click "Cancel".
Under "Look in" select the folder where the file is saved.
Highlight "HPLAOUT.INF" and click "Ok".
The Install from Disk window will reappear, click "Ok".
Select "HP LaserJet 2100 Series PCL 6" and click "Next".
Select the "Replace existing driver" option and click "Next". (This window will not come up if the uninstaller was used).
Select Not Shared and click "Next" .
Select "Yes" and then click "Finish".
Please don't skip even a step from the uninstall process. And do let me know when you are done.
Till then, Good luck.
Thanks for using FixYa.
Jun 29, 2010 | HP LaserJet 2100 Printer
Canon MX860 prints crooked!
Does this happen when printing from the cassette (bottom tray), or the sheet feeder in the back, or both? Check that the paper guides are set snugly (touching but not buckling the paper) against the edges of the paper.
Apr 29, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
HP LaserJet 2100 will not stop printing nonsense when I have cancelled and cleared the print memory. It's going through tons of paper and turning it off, along w/the computer, for several minutes does not...
The "nonsense" is your printer trying to interpret the information. Go to HP.com and download the correct drivers. Delete all other drivers from the Printers and Faxes/File/Server Properties. Then install your correct print driver
Nov 20, 2009 | HP LaserJet 2100 Printer
Printing crooked on the page.
it is due to crack in teflon sheet in printer. change it. it will work
Dec 23, 2008 | HP LaserJet 5100 Printer
Print problem
How old is your toner cart?
Have you given the toner a little shake lately?
Is there paper wrapped around the fuser causing only a partial printout?
Jun 26, 2008 | HP LaserJet 2100 Printer
Printing on paper is crooked
I would recommend a good cleaning of the rollers with a damp rag (old t-shirts are great for this). Some canned air to blow out the insides always seems to improve operation.
If this is helpful to you, would you please rate this solution? Thanks!
Jun 20, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Paper jammed
I had exactly the same problem, printer virtually new, printed great for a couple of weeks, then today refused to take paper with E3 flashing. No apparent blockage - all looked clean, tried all the utilities, roller cleaning and plate cleaning, but wouldn't take paper!
Solved it by moving the paper size guide all the way to the left, then folding the top 20mm of a sheet of A4 over and loading it so fold is at the top facing you. This acts as a catcher for anything stuck in the printer. Hold the paper slightly crooked with the left side slightly further into the printer and press the copy button (with nothing in the scanner!). It should draw the paper in now (with some persuasion) and think it is printing (it's blank,of course). Check as the top of the sheet goes in that the fold is still tight and doesn't open up as it feeds in. Lo and behold, mine brought out a 5p piece - printer now prints perfectly!
Mar 20, 2008 | HP LaserJet 2100 Printer
HP LaserJet 2100 Printer Logo
550 people viewed this question
Seeker5211
Seeker5211
