Question about Magic Chef MCD1311ST Microwave Oven
How do i cook at 50% power with Ewave rangetop microwave?
How do i change the power setting on a Sharp carousel microwave
Which model of Sharp microwave do you have?
For the SMC1441CB, after setting the cook time, press the power level button and then the appropriate digits for the percentage of full power to use. For full power, press power level then 1 and then 0. For 50% power, press power level then press 5.
For the SMC0710BB, after setting the cook time, press the Power button until you see the desired power level displayed on the LCD screen. Press Power once to get 100% power. Press Power 6 times to get 50% power.
For the R-659YW, you set the power before setting the cooking time. You press the Power button several times to get to the desired power level. Pressing Power 7 times will have the microwave cook with 40% of its full power level.
Many current Sharp appliance manuals are available on their product page or the Sharp support page. The current Sharp microwaves are listed here: http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models.aspx?facet:configurationfilter=Countertop . Other appliance manuals are available when you enter the model number in the search bar at http://www.sharpusa.com/Support.aspx .
I hope this helps.
Jul 10, 2018 | Sharp Microwave Ovens
If I want to cook a microwave dinner that cooks for 9 minutes @ 50 percent power how do I do this?
Cut the time in half if your machine doesn't have the setting for 50% power.
Jul 19, 2017 | Microwave Ovens
Power it stays at 100% want 50%
Most microwave ovens I am familiar with have adjustable power levels.
Sep 11, 2016 | Panasonic NN-H765BF 1250 Watt Microwave...
Ewave microwave
Over the range microwaves are generally the same as far as the rear dimensions but you will still need to install new mounting brackets and drill new holes in the cabinet. Each brand is slightly differnt in its mounting.
Nov 25, 2013 | Microwave Ovens
On my ewave over the stove microwave oven, the light and the turntable are not working, yet the microwave seems to cook VERY quickly. Should I replace a fuse or is it likely something else?
this device is driving by the motor, but however is must take holding by a certified repairmen.
2) test the rollers assembly, is working good see your instruction manual.
3) the light you must test with VOM , is open the filamente and replace. you must remove from the kitchen unit. Unplug the power before to do anything.
God bless you
Jul 10, 2012 | Microwave Ovens
Change handle on ewave microwave
Take a look on amazon for replacements, here Amazon com microwave handle. I hope this was helpful. cheers
Jan 15, 2010 | Microwave Ovens
E-Wave over the range microwave has blown main fuse
My Ewave has stopped heating eventho it appears to be running. Is is possible the power has been reduced or does the microwave need to be replaces
Nov 16, 2009 | Microwave Ovens
How do you set whirlpool microwave to 50% power
The microwave oven should be at a temperature above 50°F (10°C) ... microwave oven can be manually set to defrost. To defrost. manually, use 30% cook power. ...
www.whirlpool.com/assets/pdfs/product/ZUSECARE/8205987.pdf
Jul 03, 2009 | Whirlpool GH4155XP Microwave Oven
Howm do I reduce power down to 50%
First enter the cooking time just like normal, but then you hit the power button and then hit the digit indicating the power level you want. THEN hit start and it will start cooking.
Mar 08, 2009 | Danby DMW119 Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCD1311ST Microwave Oven Logo
79 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
