Question about Canon IXUS 80 IS Digital Camera
I have a memory card error appearing on my camera. My camera is ok just the memory card as i have tried using another card in my camera. It happened last night after taking photos when my battery was low. Can you help?
  • Canon Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Jul 30, 2010
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
Took the memory card out of my camera yesterday. when i put it back in it displays CHA on the screen. what happened? i can't use my camera.
The CHA error indicates an issue with the memory card in the camera.
Try another card and see if that works ok.
Also, always format cards in the camera.
In case the error comes back on a new card, you will need to send the camera to Nikon.
I will appreciate your feedback and positive rating for this free solution.
Sep 30, 2010 | Nikon D100 Digital Camera
Memory card error
Did you format the card in the camera before trying to use it?
Sep 02, 2009 | Canon PowerShot A700 Digital Camera
My cybershot w120 keeps saying no space on internal memory when i have a new memory card in it which is empty. This happened with my last card so now i am thinkng its more a camera problem rather than the...
in your settings is it set to "shoot without card"? this could cause the camera to not use the memory card installed and rely on internal memory which is limited
Aug 26, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
File Error report on a W80 camera....
have you tried resetting your camera to original factory settings.if not please try it...
May 28, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Changing memory cards
I WOULD PROBABLY SAY YOU HAVE A COMPATIBILITY PROBLEM BETWEEN THE POLAROID SD CARD AN YOUR KODAK CAMERA AND THAT IS WHY IT IS NOT FORMATTING. GO ONLINE TO EITHERS SITE AND ASK TO SEE IF THEY ARE COMPATIBLE. THIS MAY SOLVE YOUR PROBLEM.
Oct 30, 2008 | Kodak EasyShare C613 Digital Camera
Samsung nv3 sd 'card error ! ' message
my camera say card error, can u help?
Apr 04, 2008 | Samsung NV3 Digital Camera
I had the same problem.
First, I changed my Memory-Stick, because after taking about 60 pictures the famous file error appeared.
Secondly, if the camera shows the famous "file error" this can be resolved - at least in my case - by taking out the battery for at least 4 hours.
So, if your camera is not in use, always take out the memory-stick and the battery and the problem does not appear. This helped in my case.
However, this is in my opinion anything but satisfying. I had a Nikon Coolpix nd never experienced any problems like the "file error" of the sony digicams.
Oct 27, 2007 | Sony Cyber-shot DSC-W80 Digital Camera
Card Error
This is from Konicas site. don't know if this will be any help for you since you had posted a long time ago. you most like have a new camera by now. anyway. Question: When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the monitor display. Answer: Please follow the procedure below. While the message is displayed, press the center of the controller. The monitor display and data panel will turn off. Turn the Main Switch dial to OFF position and remove the CompactFlash from the camera. - When "No Card" message appears next time when the camera is activated in the recording mode, the camera and CompactFlash are OK. - When "Card Error. OK" appears again, the CompactFlash may be faulty. Use other card.
May 05, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Canon IXUS 80 IS Digital Camera Logo
188 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
