Question about Jabra FreeSpeak BT200 Consumer Headset
How do I pair it to my phone. I have no manual
  • 638 Answers
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jul 30, 2010
Sm-g31or5 want to pair with my 07 toyota solara convertible. phone says paired, but not car
Just had to pair for a friend few days ago, Toyou press setupota will pair to audio, but not hands free talk. Not sure exactly what buttons to push on your particular, so I would suggest read your car manual for "Hands Free Bluetooth" Pairing, not just audio pairing. On Toyota that I paired, after you press setup Bluetooth you will have to press "Phone Off" button on your steering wheel to get into hands free pairing, but check your manual to be sure.
Apr 09, 2015 | Samsung Cell Phones
I have nokia 6120 classic with BH-100 ear piece, how do you get the hands free ear piece to work
just go into the settings & there you will Accessory settings..
Thank you
May 21, 2008 | Cell Phones
My phone is asking for the numeric passkey for motorola when attempting to pair it...
It depends on what you are trying to pair it with. If it is a headset, for example, you may need to refer to your manual. I had a plantronics bluetooth headset, and I believe the code was just 0 0 0 0. If you are pairing with something that has a display, try looking at the screen and seeing if you can enter in a code. If not, try it the other way around. Instead of using the phone to pair with a laptop, try using the laptop to pair with the phone.
If you need the manual, try the manufacturer's website, otherwise amazon.com has a lot of manuals for products.
Mar 08, 2011 | Cell Phones
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
Pairing an "universal" bluetooth to the samsung behold
Do you still have the user manuals for both the phone and the IHF1000? Start by reading the bluetooth pairing sections in both manuals and trying what is listed. If you have already done this, then please detail where you are having difficulty in the pairing process.
Apr 20, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
Syncing blooetooth
Headsets don't be synchronised, as syncing means to update to devices with each other.
Bluetooth headsets are paired. Pairing means that both Bluetooth devices recognize each other and trust each other, so you do not need to provide any type of confirmation.
So, follow the phone's manual to see how to switch on the Bluetooth and make it visible. Now, there must be an option like make a new paired device. Consult your manual for this. The phone will search for a deivce and they will be paired.
You can even pair a PC and phone, phone and phone and every kind of Bluetooth enabled devices.
Jan 30, 2009 | Motorola Mobility H700 Wireless Headset
How can i reactivate my blueant blue tooth on my motorola ic902?
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 15, 2008 | Blueant Supertooth Light Bluetooth Speaker...
N73 not pairing with visorlite
here's the manufacturer's website where you can download the manual (it is also marketed as Supertooth Light)
http://www.supertooth.net/down_light.html
Mar 13, 2008 | Nokia 6300 Cellular Phone
Jabra FreeSpeak BT200 Consumer Headset Logo
125 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
