Question about HP Deskjet 6940 InkJet Printer
Printer Toolbox Not Recognizing New Black Ink Cartridge
I recently replaced my black ink cartridge in my HP Deskjet 6940, however the printer's toolbox on the computer still only sees that there is low/no ink as far as the black ink goes. I have already tried reinstalling the printer's drivers and that didn't work. Any ideas or suggestions? I would really appreciated it, thank you.
Pop out the cartridge and look inside the printer where the black cartridge goes. There may be punctures in the ribbon cable from the metal wire that rests against the catridge. I have lost 2 6940's to this problem.
Posted on Jul 07, 2008
How do i check the ink level on my 6940 inkjet printer ?
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Solution Center , select Settings , and then Printer Toolbox .
    • If the HP Solution Center method does not work, open Printers and Faxes in the Windows Control Panel, then right-click the printer icon and choose Printing Preferences . Click the Features tab, and then click the Printer Services button.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows otherwise. (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
Mar 26, 2011 | HP Deskjet 6940 InkJet Printer
Hp6940 ink and printing problems
you may have a bad print cartridge or it has gone bad...
Dec 21, 2009 | HP Deskjet 6940 InkJet Printer
HPofficejetpro L7580 doesnt recognize cartridges have been replac
hELLO THERE
there should be a section there for the maintenance of the cartridges and change cartridges make sure that you use this whenever you change out a cartridge cause if you use this when you change out the cartridge the printer will always show low on ink also you can reger to your users guide for further instructions on how to do this ok? hopethat this has been very helpfull dont forget to rate my solution
best regards mike
(USN) retired
Aug 05, 2009 | HP Deskjet 6940 InkJet Printer
I have a HP Deskjet 882C printer and for the past month we are having problems printing text (B&W). We have removed the black ink cartridge and it still has a lot of ink in the cartridge. When we put a...
To clean the HP Inkjet print cartridges from the HP Toolbox, using a Windows operating system, perform these steps:
  1. Double-click the HP Toolbox icon on the computer screen.
  2. Click the Printer Services tab.
  3. Click Clean the print cartridges and follow the directions on the screen.
If the print quality improves after completing this sequence once, but the quality is still not quite good enough, repeat procedure. Start at Step 1, or click the Clean Again button on the final cleaning window. If this process does not improve the print quality, the HP Inkjet print cartridges might be low on ink. See the document that is provided with the black HP Inkjet print cartridge for instructions about how to use the ink level sensor to determine if the cartridge is low on ink. Replace the HP Inkjet print cartridges, if appropriate.
Jun 25, 2009 | HP DeskJet 882c InkJet Printer
Install cartridge missing on Deskjet 6940
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
May 27, 2009 | HP Deskjet 6940 InkJet Printer
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
I have a Deskjet 6940 printer and ive bought a HP348 photo colour ink cartridge. it wont fit in the slot!? Does it go in the colour slot?
Your printer doesnt support HP348 cartridge.
HP 99 Photo is the cartridge meant for 6940 which wud go in the slot for black cartridge. and you can print approx 130 photos .
Mar 28, 2009 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
The Deskjet 6940 will only show ink level for original HP cartrdgies. Refilled or reman cartridges will show as empty or unknown in the toolbox. This is not an issue with the driver, the cartrdige itself has information that it has been previously used and this is not resettable. You can continue to print with a cartrdige that has unknown ink levels, you will just not get low ink warnings.
Regards,
Bob Headrick, Micosoft MVP Printing/Imaging
Apr 24, 2008 | HP Deskjet 6940 InkJet Printer
HP Deskjet 6940 InkJet Printer Logo
537 people viewed this question
Seeker5211
Seeker5211
