Question about Kenwood KVT-617DVD Car DVD Player
The screen will only come out part way or not at all and sometimes all the way but no adjustment
    Guru:
  • 632 Answers
The movement motor or belts have broken or come loose, You will need to take the radio out and remove the top of case and Make sure belt is on the cogs proper.
Posted on Jul 31, 2010
How to adjust analog time in my g shock 20 bar
Press the "Adjust" button. It's usually the top-left button, slightly smaller than the rest. When you have successfully pressed the button, one of the numbers on the screen (generally the seconds) should begin to flash.
Choose which number you would like to change (hours, minutes, day, etc.) by using the "Mode" button on the bottom-right to cycle through each option on the main screen. You'll know when you have reached your target position because that number will flash.
Use the top-right button (usually labeled "Start/Stop," or sometimes "Light on/off") to change the number once you have highlighted the position you wish to change. When you have finished making the desired adjustments, press the "Adjust" button again to complete the process.
Use "Adjust" on any screen of your Casio G-Shock watch. To reach the watch's other screens, press "Mode" (bottom-right button). Most G-Shock watches have four screens total, including the main screen. On each screen, use the same process described above to make adjustments to the time (with the exception of the stopwatch screen, which does not keep time.)
Mar 15, 2017 | Watches
Is there a way to adjust the picture size? On some channels the picture is cropped at the bottom.
this is an aspect ratio problem ans is corrected /adjusted on the on screen menu
use the remote to achieve the on screen menu and scroll around until you find aspect ratio
use the volume buttons to select and adjust
Apr 27, 2015 | Sony 40" FD Trinitron WEGA XBR Hi-Scan TV...
Aspect ratio is incorrect, not proper screen size
Check its user manual for details about adjusting the aspect ratio or contact the dealer.
Apr 17, 2013 | Insignia Televison & Video
My tv the screen there are line and sometime no draw?
If there are lines on the screen [parellel lines across the screen horizontally, at about an inch or so apart], your tv needs screen adjustment. Its screen voltage is now high. It can be brought low by adjustments. There is a screen adjustment control, usually integrated with Line Output Transformer. If you know, you yourself can adjust this. It is an internal adjustment and need to open the back cover of the TV. Don't use your TV for long time without rectifying this problem. It may get picture tube damaged. The electron guns inside the picture tube neck will get red hot and its emmision will be reduced.
Oct 18, 2010 | Sharp 32C241 TV
Changed color wheel on samsung dlp. now getting a blured blue screen which covers 75% of screen.
Sometimes on the DM board of the light engine it has a small black jumper that sometimes needs to be removed and colors are restored, sometimes might need adjustments in service menu.
Oct 28, 2009 | Samsung HCM4215W 42" Rear Projection...
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Adjusting
You have the closed caption turned on the set. Since you did not leave a model number, I cannot tell you the procedure on how to turn it off. Sometimes there is a button on the remote marked CC or closed caption, and sometimes it is switched on and off through the on screen menu. Good Luck
Jan 04, 2008 | Televison & Video
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Kenwood KVT-617DVD Car DVD Player Logo
71 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
