Question about Extron Electronics Extron SW 6 VGA xi (60-259-01) KVM Switch
I have a problem with the Extron SW 6 VGA xi KVM Switch i get after abaut 5 min some lines in the view on my projektor after a wile it will be get worst i tried to take a foto but the foulty view is to fast for the camera my resolution are 1280*1024 i also put out the power of my laptop but the same without the extron all is fine thanks marco
Try another input on switcher. Did you have any other equipment connected between switcher and the projector, if yes, bypass it. Call Extron Support they are very helpful and they provide free support.
Posted on Aug 26, 2010
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Jun 13, 2014 | Acer 22" X223w LCD Monitor
The extron is only flashing lights but not working. what could the problem be?
Flashing lights mean power failure, you have to send the unit to Extron for repair. Extron has 3 years warranty, they can check if the unit can be repaired at no cost.
Aug 26, 2010 | Extron Electronics Extron SW 6 VGA xi...
Mam projektor benq mp 610 taky problem ze sa my mali hral s projktorom a pita to odomna heslo nakolko som si precital manual nic tam take neni vopred vam dakujem
Poruche projektor môže byť príčinou neuveriteľného smútku, najmä ak sa to stane skôr, než veľká prezentácia. Učenie niektoré rýchle tipy pre projektor môže ušetriť čas a námahu, a pomôže vám zabezpečiť prezentáciu jede bez problémů.
Skontrolujte napájanie. Ak je projektor nie je zapnutie alebo vypnutie, uistite sa, že napájací kábel je správne pripojený k projektoru a zapojený do zásuvky bezpečne. Tiež sa uistite, že projektor je správne pripojené k počítaču.Krok 2
Uistite sa, že projektor nie je prehriatiu. Skontrolujte, či ventilačné otvory, aby sa ubezpečil, že nie sú blokované. Tiež zase projektor vypnúť po dobu najmenej 20 minút, aby ju vychladnúť.Uistite sa, že miestnosť, v ktorej používate projektor nie je príliš teplé. Niektoré projektory pracujú najlepšie v chladnejších miestností.
Jul 31, 2010 | BenQ MP610 Multimedia Projector
I need to know why the screen on my Extron RGB 109xi is flashing. By the way, this equipment is not a KVM switch...
The internal (replaceable) power supply has failed. If you are good at fixing things - soldering, etc. - you can replace the power supply with a Digikey part #285-1779-ND (KMD15-55)
Just be careful and mount it to the top aluminum cover with epoxy.
Richard C.
Apr 07, 2010 | Extron Electronics Extron RGB 109xi KVM...
Eurovox
They have changed the keyroll method and auto update will not work for now so you have to manually input keys everytime they change:
1. Press Menu, press OK on language settings.
2. Press 1968 TWICE on your remote.
3. Key screen will open, use the < or > button on remote to get to Nagravision screen if it is not visible.
4. Press OK on N**. Go down to key data field and enter codes for line 00 first. Use < or > arrows on remote to change numbers/letters.
5. When done press blue button to save and exit.
6. Now scroll down to second N** line and press OK.
7. Do same as above and change key data field for line 01.
8. Press blue button to save and exit.
9. Exit out all the way to view channels.
Sep 17, 2009 | StarTech.com StarView SV211K 2-port KVM...
Need password for star view box
The default password is 0000 If that doesnt work turn the unit off using the switch on the back, wait a min and turn back on. Hope this helps
Jan 25, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Password reset for ATEN kvm switch
If you are unable to perform an Administrator login (because the Username and
Password information has become corrupted, or you have forgotten it, for
example), there is a procedure you can use to clear the login information.
To clear the login information do the following:
1. Power off the CN8000 and remove its housing.
2. Use a jumper cap to short the jumper on the mainboard labeled J6.
3. Power on the switch.
4. When the front panel LEDs flash, power off the switch.
5. Remove the jumper cap from J6.
6. Close the housing and power on the CN8000.
After you start back up, you can use the default Username and Password (Login: administrator, pass: password).
Dec 12, 2008 | Videk ATEN Master View 9834 KVM Switch
Cannot switch between PC's
That unit mention above is a Mountable Dual Output VGA to UXGA Distribution Amplifier with Audio not a KVM Switch.
Apr 07, 2008 | Extron Electronics Extron P/2 DA2 MT...
I was tring to Connect Two Computers to One Monitor, but i didnt get it, does someone know how to do so? I bought a KVM switch, USB to use between a new Acer running Win XP and old Dell with Win 98. Could...
I guessing that since **-one responded you've given up and returned the whole mess but what the hey.
A lot depends on the KVM you're using. There are some high end units that will match different sources to the monitor but most work best with matched input and output. Unless you's specifically states that it will convert analog to digital it won't. So if it's an analog KVM then both the computer video boards need to have an analog VGA jack and the monitor does too. If the KVM is ditital you need to have all the systems and monitor digital. Savi? The Monitor may support boath analog and digital input but NOT at the same time. You can't plug in two computers at the same time, that's what the KVM is for.
The bottom line here is that you typically need to run the least common de**minator to use a KVM. Also, if the computers have different frequency (resolution) out put and you hit the KVM switch then the monitor will freak out. Some monitors will auto-switch between frequencies but most don't (especially the cheapies).
There are adapters that will down convert digital to analog. If you're dead set on using the KVM with that old Dell then you may need to plug the down converter into the Acer Video Board but you'll loose the high resolution and sharp picture from the digital video. If it was me and I had to use the KVM, I'd get a cheap digital video card for the Dell or just run two monitors.
I run 5 systems on my desk, Three of which are older servers with analog video. They share an analog KVM with video and keyboard on the wall. The other two systems are current generation and share a KVM and 27" flat panel center desk. I also have a laptop that hangs on the other wall with a laser blue tooth keyboard on the other side of my desk. Now if my wife would only let me turn part of her craft studio into a server room.....
Feb 14, 2008 | AOC 19LVWK LCD Monitor
VGA Splitter frying video cards?
We have Extron Crosspoint switcher 300Series 128 when we switch ON the switcher it will not Powering ON can you helpme out how to solving this problem
Nov 01, 2007 | Extron Electronics Extron P/2 DA2 MT...
Extron Electronics Extron SW 6 VGA xi (60-259-01) KVM Switch Logo
147 people viewed this question
Top Extron Electronics Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Extron Electronics Computer and Internet Expert? Answer questions, earn points and help others
