Question about Canon PowerShot SD870 IS Digital Camera
I had deleted the photos then charged the battery. when i turned on the camera to take photos it wouldn't let me shoot and the screen say's Card locked
  • Canon Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Jul 30, 2010
While deleting photos camera shut dow
May I suggest the battery was very low. The Nikon delete routine shows a bright display after the file is deleted, this may take a bit of power. May I suggest you work on your files on your computer? That is, that the SD card out and work on the files on the computer. Now I suggest charging the camera and taking out the SD Card and then turning it on. If it works try it again with the SD card in.
Jun 20, 2014 | Nikon Coolpix S4000 Digital Camera
Memory card is full and when I plug in the USB cord and turn on the camera I get a message that my device is not connected or is busy, or that it contains no pictures!!
Causes of memory card corruption
  • Turning off a camera before an image is completely written to the memory card.
  • Removing the memory card from a camera while an image is being written to the card.
  • Removing the card from a memory card reader while files are still being transferred to a computer.
  • Batteries conking out as files are being transfered directly from the camera to a computer. Note: always make sure you have fully charged batteries before transferring images.
  • Removing the card from a card reader while folders and files from the card are open on a computer.
  • Opening, deleting, renaming or moving files on the card while its contents are open on a computer.
  • Using a memory card which has not been formatted in the camera. Use the delete/erase function when needed, however a card should be regularly formatted.
  • Formatting a card in a computer instead of the camera.
  • Inserting a second memory card into a card reader before closing and removing the first when viewing images on the card from a computer.
  • Taking photos when camera batteries are nearly empty.
  • Taking photos too rapidly so the camera can not complete writing one image before starting the next.
  • Continually shooting and deleting, shooting and deleting images when the card is full.
  • Letting a memory card get too full before downloading the images to a computer or storage device. Cards that are too full may overwrite the card headers.
  • Using a memory card from one camera in a different camera without formatting it in the new camera first.
Feb 28, 2008 | Cameras
When switching camera on there is a blank screen
In settings, you might have switched off the image for when the camera starts. Turn it back on. Also, if that doesn't work, try deleting some photos or change the sim card or the battery itself, not charge it.
Apr 15, 2014 | Canon PowerShot G10 Digital Camera
I have a new EOS T3i. It's my first digital camera. I took out the battery to preserve it. When I reloaded it, the camera wouldn't let me take any pictures. The message said the card wasn't...
That sounds like an issue with the memory card. Yes you will lose all current photos on it when you format the memory card. It's also safe to leave the battery in the camera as DSLRs don't drain power when the camera isn't in use.
Jul 23, 2011 | Canon Cameras
Flash card error appears on the screen and stops the camera from shooting
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory card
Jan 28, 2011 | Olympus EVOLT E-410 Digital Camera
Pauses between takes
THE PAUSE TIME YOU ARE TELLING IS THE TIME TAKEN BY CAMERA TO READY AGAIN. YOU CAN NOTICE THAT WHEN YOU SHOOT PHOTO WITHOUT FLAST/OUTDOOR IN DAY TIME THAN IT DO NOT TAKES TIME PAUSE. WHEN CAMERA USES FLASH IT WILL TAKE TIME TO BE READY FOR NEXT SHOOT. IT IS NORMAL
May 19, 2010 | Nikon Coolpix 4600 Digital Camera
I'm having 3 different problems with my Canon Rebel XT
According to Canon, Error code 02 means that "There is a problem with the CF card. Try any of the following: Remove and re-insert the CF card. Format the CF card, use a different CF card."
Are both CF cards the same brand? Sometimes some brands have conflicts with the camera, you might try using two different brands.
It may not be the card, did you try on the third attempt to remove the battery and put it back in? There may be a problem with the contact points where the CF card plugs into the camera, or in the transfer system itself.
Dec 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Extreme Difficulties With My Canon
Problem #1
this is not a problem.. if you leave the camera in the ON setting for long enough.. it goes to sleep ... in order to conserve battery life.. you need to keep some of the buttons pressed for a bit for it to wake up... e.g. keep the picture taking button depressed for 5 secs.
Problem #2
If you were checking the pictures after just shooting them then its probably a CF card problem. You can also get the same error .. i.e. corrupted files from the cameras perspective.. if you use a CF card reader and try to change the pictures on the card.
You should try to connect the CF card that has those pictures to a computer it might be able to open them.. .
Otherwise try another CF card.
Nov 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Vivitar Vivicam 8300s blank screen/won't shoot
From all those problems-each one a different component I can only surmise a number of thingsthings. Battery is either dead and needs changing or re-charging. Battery contacts in the inside of camera dirty/corroded Media card asbsent. Check all these things then come back
Sep 07, 2007 | Cameras
The camera does not take a photo when I press the shutter button. What should I do?
Check the following: * Make sure the battery or batteries have power and are correctly installed. You may need to replace the batteries. * Make sure the power is on. The camera may have turned off automatically to save power. Press the POWER button to turn the camera on. * Make sure the Mode dial is set to the correct mode. The shutter button will operate when it is set to Manual mode, Automatic mode, Continous shooting mode and Video mode. * Check the number in the lower left corner of the Camera’s LCD screen. If the number is 0, the memory card (or internal memory) is full. Copy the photos to a computer and delete them from the camera.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Canon PowerShot SD870 IS Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
