Question about Spidem Trevi Automatic Espresso Machine
Clicking noise in place of grinding and dispensing liquid;
Preparation process begins, when you hit the start button, but machine begins a regular clicking noise instead of or at the same time that the liquid used to spurt out and the coffee bean light goes red. Clicking noise continues until you turn the machine off. No grounds are produced in side bucket.
I also can't get grinder to slide forward / toward me by pressing the 'Press Here' lever just inside the front cover (at one time I thought I was able to)?
  • 1,089 Answers
Hi
Your brew gear drive is broken. Your doser knob is det to the max and you got an over charge in the brew unit that the drive could not compress and it broke some of the teeth on the gear. You will have to replace the gear and make sure that it is timed before testing or you will break it again.
Posted on Jul 30, 2010
Testimonial: "Thank you. How long might a repair place ($60 for the first hour, $30 each addtl.) take to fix it? I paid $19 for it 3 years ago ..."
NEED TO GET OUT OF THE DESCALING PROCESS. HOW CAN I DO THAT?
Descaling instructions:
  1. Press the " " button until the CACL CLEAN symbol appears. Press the " " button to start the descaling.
  2. The machine reminds you to insert the carafe and pull out the what is in there dispenser. The descaler symbol appears on the display. ...
  3. Take out the water tank. Pour the entire bottle of Saeco descaling solution in the water tank.
  4. Top up the water tank with fresh tap water to the MAX line. (Please ensure the max line is reached otherwise this will require further rinsing). Place the water tank back into the machine. ..
  5. Place a bowl underneath the milk carafe dispenser and the dispensing spout.
  6. Pull out the milk carafe dispenser to the right up to the " " icon.
  7. Press the " " button to start the descaling cycle.
  8. The machine will start dispensing the descaling solution at intervals. The bar on the display shows the progress. This takes about no moro then 25 minutes.
Sep 28, 2016 | Coffee Makers & Espresso Machines
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
I have a whirlpool wfs 1071aw and havent used washing liquid before only powder...cant find my manual and when I put the liquid where I would have put powder it leaks soap out of the dispenser onto the...
You should have a little divider in the soap drawer , it needs to be moved into a different position for liquid ( holds the liquid until the cycle begins)
Mar 15, 2011 | Washing Machines
Mixer makes a loud ticking or clicking sound at low to moderate speeds, like a clock tick. At faster speeds and high speed, the loud tick is drowned out by a louder grinding sound. All of this sounds...
I don't have a direct answer for you. There are many things which could cause the noise from a beater simply hitting the bowl to internal gear problems. You did not say which model you have so take a look at the two Service Manuals linked below. One of these ought to cover your machine.
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
Apr 06, 2017 | KitchenAid Food Mixers
Have a 04 dodge with a driver side grinding noise that comes and goes. It started after I got my truck stuck in the snow. I thawed out the front end last night, and now its worse. It comes and goes while...
C V Joints can make a lot of noises. Sounds to me like you either bent the inner fender or if it is plastic you may have pulled it loose and it looks normal but it is just sitting in place with the push pins out of their intended holes. When you turn and or hit a high speed it hits the wheel/tire. Try putting on some gloves and then pulling medium strength on the fender well and surrounding areas to see if that is the problem -
Feb 03, 2010 | Dodge Ram 1500 Cars & Trucks
The inside of my washing machine smells
Regular cleaning maintenance is required to prevent odor build up inside the machine. The LG WM2688HWM has a TUB CLEAN feature, a special cycle for the cleaning of the inside of the washer. This cycle uses a high water level with higher spin speed.
  1. Remove any clothing or items from the washer and close the door.
  2. Open the dispenser drawer and add liquid chlorine bleach ONLY to the bleach compartment.
  3. Close the dispenser drawer slowly to prevent the bleach from spilling.
  4. Turn on the machine then press the EXTRA RINSE button for 3 seconds.
  5. Press the START/PAUSE button to start.
  6. Leave the door open to dry the washer door opening, door seal and door glass after the cycle is complete.
Dec 02, 2009 | LG WM2688HWM TROMM SteamWasher
My fridge made a horrible grinding noise. When it
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Jul 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My Kenmore Elite front loader HE3 washer will not start.
The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
Eric
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool side by side fridge stops cooling/freezing!!!
No its not button I would know about after 30 some years. You may be having 2 or more symptoms begin caused by the same problem though. The noise at night tapping may be because (and indeed may be doing it ll the time you just don't notice it due to the angle of echo in your home and kitchen) I suspect the fan blade (Im betting on the one behind and below by the compressor) is either bent slightly or hitting. something. I have seen anythign from mice to papers get close to the fan blades and cause a mistery problem. This would explain the defrosting also especially if it cant get going again.
Take off the back cover and look for the fan motor and spin the fan if its stopped. You also need a strong flashlight to look out for what might be causing it. If it is a mouse dont worry he will only be bothering those cats that have lived into the 10th life.
As for the grinding noise.../when you get water... and the leaking... is the leaking comming form the water area or the defrosting? Ok you say defrosting so that could be explained by the outer fan. The noise though maybe even the cardboard baffel in the back is getting in the way of thatfan in back. And i think it might be your water line gettign hit by this fan. That would tie in and make all the trouble stem from a water line hitting the fan. If tihs is it please tell me so I can recover from not knowing if Im helping people out here. Im beginning to think Im wasting my time. Please post more so I'll know.
And if you tell me, please rate me too
Mar 15, 2009 | Whirlpool ED2FHEXN Side by Side...
Fault 10 appeared
Fault 10 indicates "No Water is Dispensed."
Solutions =>
– The water tank is not inserted properly. Take it out and reinsert correctly.
– The water tank was not filled correctly during the descaling process. Fill the water tank up to the correct mark.
– After fixing the fault, the machine turns off then on again. Start the desired preparation again.
– If the message still appears contact Technical Service
See page 52 for Fault Codes and Solutions in the owners manual.
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Sep 07, 2008 | Miele CVA4070 Coffee Maker
Spidem Trevi Automatic Espresso Machine Logo
735 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Mike
Mike
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
