Our Clothes seem to smell after being washed, checked drawer and found lots of mould etc how do get rid of this problem, why does the drawer attract this mould? i wash reguarally.
    President:
  • 2,702 Answers
Its a comon fault,,,i would put in a strong vinegar into the drawer and do a rince with nothing in the washer first this will kill off any mould after that do a fuw rinses and then leave the door open after you use the washer to stop any more mould growing in it this also works on wood and walls too!
Posted on Jul 30, 2010
How to get rid of black residue from lg washing machine
The black residue indicates a mould problem. There seem to be a lot of people reporting this problem on the LG washing machines on numerous forums. Since you are dealing with mould you should exercise proper precautions, including wearing a mask, so you do not breathe in the mould. If mould gets into your lungs, you will never be able to get rid of it.
To clean up the mould use plenty of bleach. Make sure to remove the dispenser door to get at the spots where the mould tends to build up. To prevent it, leave the washing machine door open after every wash.
Aug 13, 2014 | LG Washing Machines
Model WF7700N6W1 - front loader - smell? Rubber seal inside door peels back a bit to reveal buildup of gunk between seal and inside frame? retaining water here?
Ok, nothing to worry about. You have bacteria growing in your machine. Clean out the slime from the door seal using a soft cloth and soapy water. DON'T use any harsh chemicals such as bleach !
Remove your detergent drawer (if possible) and clean it thoroughly - a dishwasher will do this very well. Disconnect your machine from the power supply and clean thoroughly inside the space where the dispenser drawer was, using a toothbrush or larger nylon brush and a soft, soapy cloth.
Using liquid detergents all the time can cause a build up of residue over time, which gives the bacteria and mould somewhere to grow. So try a hot wash cycle (without a load) using a powder detergent intended for whites. Washing powders contain brighteners and chemicals which are hostile to mould and bacteria.
Finally, leave your dispenser drawer and loading door open every night to allow fresh air to circulate through the entire machine. This will reduce the number of cleaning occasions needed.
Jan 10, 2018 | Samsung WF337AA Front Load Washer
My washer has a sewer smell and it is causing the clothes to smell, how do i get rid of the smell
Front load machines have this issue and the solution is to run a cleaner through the machine, routinely. They all do it, which seems strange to me...
Be sure that your discharge hose goes higher than the machine top, and has a vacuum break, so it cannot draw sewage back into the machine (less likely that this is an issue).
Mar 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
My clothes have a musty smell after being washed
run a wash load (no clothes) with 2 cups of Clorox brand bleach and use hot water, that should help.
Nov 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Terrible smell coming from washer while in rinse mode.
This is classic bad design actually.
Some washers are worse than others for this.
Use an oxygen based bleach in a trigger spray, and remove the detergent drawer. Use the spray everywhere in there - and remove the drawer completely to wash it in a mild bleach solution.
Use a small brush to remove the mould in there - and flush it down the pipe with more spray.
If you an get a foaming cleanser down there - then even better - or an alcohol based sanitiser spray.
Also wipe over the door seal rubber - as this sometimes collects stagnant water in the folds.
Reassemble, and do a hot wash with a few white hand towels to remove all the bleach.
You may need to do this every month.
Doing hot washes helps - maybe with a cap of bleach.
(I think the manufacturers do this on purpose - so you wash more often - breaks machines - you buy a new one etc.)
Aug 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
The fabric softener tray is full of water when wash has finished
The 2 probs could be related.
The first you need to do is remove the dispenser drawer, and thoroughly clean every part of it, particularly the conditioner compartment, poke clear all the tubes and apertures you can see,the problem is caused by a blockage.
The smell is related to the fact that the waste pipe is probably connected to your sink waste, you need to remove the pipe and check for partial blockage, or if it goes to an outside sink , then you need to get some kind of drain cleaner to pour down the sink..
Also , at least once every 6 weeks do a hot wash with powder, but no clothes in, this helps to keep the m/c clean and prevent build up mould and dirt inside the m/c..
Clean the door seal regularly, when you finish a wash.and leave door open and dry it
This should help disperse the smell.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Hotpoint Ultima WD72 Front Load...
Bad smell in our washing machine LG Front Loader WD-8074
You don't have to drain all the water out after each use, you just need to clean things up a bit.
There is a problem with the design, in that the drawer area is a breeding ground for mould.
There will be a latch on the drawer you need to press to remove it - take it out and wash it in a hot solution of borax. Alternatively bleach it, and then wash in hot detergent.
Use a spray cleaner designed to kill mould and mildew, and use it with a brush inside the drawer apature to remove all mould build up. It's quite a grotty job - but needs doing.
After that, use a cloth to clean as far back into the pipe as you can.
Do two washes on hot with bleach, then a rinse, and it's good to go.
It is most important you leave the drawer open after a wash, and the door open more than 2" on these machines to prevent it, and a hot wash occasionally for whites. Tell the manufacturer that you won't be buying their brand again.
Dec 04, 2008 | LG WM1812C Front Load Washer
Clothes come out of washer smelling musty
It sound like lint bult up under agitator orIn Between inner and outer tub it would have to be manualy cleaned thanks and good luck:)
Nov 16, 2008 | Maytag MAV3855A Top Load Washer
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
