Question about HP Officejet 5610 All-In-One InkJet Printer
What is cartridge error and how do you resolve it
    Guru:
  • 731 Answers
Click here to find the troubleshooting steps to resolved cartridge issues.
Regards
Riztech
Posted on Jul 30, 2010
My Lexmark printer when turn on it makes noise and it can not print with a error code 2200
Hello thanks for using Fixya
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Step1.
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes:
Continue to step 2.
No:
Attempt a test scan. If the error message does not reappear, the error is resolved.
Step2. Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.Did the error message return?
Yes:
Continue to Contacting Lexmark.
No:
Continue to step 3.
Step3: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes:
Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No:
Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Step4: Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes:
Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No:
Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 11, 2011 | Lexmark P4350 All-In-One InkJet Printer
What is error #2200
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
New cartridge, says cartridge error
1. Try removing the cartridge and unplug units a/c power.
2. Find a damp cloth and wipe the output ports on the bottom on cartridge. .
3. With a Q-tip, go over the round copper pumps on the cartridge tray. ( Where the cartridge makes contacts. )
4. Close door and power up unit.
Unit will give you a error message cartridge not installed.
5. Install the new cartridge.
Close door and fallow any additional instructions given.
( A ) If this does not resolve your problem, re-install old cartridge and see if you get the same error message. If you do not, replace the new cartridge.
Hope this has resolved your problems.
Please rate your techs.
Oct 06, 2009 | HP Officejet J3680 Multifunction Printer...
What does error code 2200 mean?
Printer Reset
Step Action 1
No: Attempt a test scan. If the error message does not reappear, the error is resolved. 2
No: Continue to step 3. 3
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved. 4
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Sep 25, 2009 | Lexmark X7170 All-In-One InkJet Printer
Cannot print true color.
How do I resolve the error message "Calibration Page Not Found"? Error code: 3610 Question : How do I resolve the error message "Calibration Page Not Found"?
Answer : To resolve this error condition, correctly position a calibration page on the scanner. See the User's Guide for more information. How do I resolve the error message "Cover open"? error code : 3501 Question : How do I resolve the error message "Cover open"? Answer : To resolve this error condition, close the access door. The printer will not operate while the door is open. How do I resolve the error message "Color ink cartridge missing or not installed correctly"? Error Codes : 3511 Question :
Answer :
To resolve this error condition, reinstall the ink cartridge:
  1. Remove the color ink cartridge:
    1. Open the printer access door by lifting from the front center of the unit.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
  2. Check the two electrical contacts on the ink cartridge for small marks, which should appear if the cartridge was installed correctly.
    If the electrical contacts do not have small marks:
    1. Reinstall the ink cartridge, making sure you press down on it until it clicks into position.
    2. Remove the color ink cartridge, then check the two electrical contacts on the ink cartridge again for small marks. Repeat if necessary.
    3. Reinstall the ink cartridge.
  3. Close the printer access door.
NOTE: See the User's Guide for more information about removing and installing the ink cartridge.
If the error persists:
  1. In the KODAK All-in-One Home Center, select the Help (?) icon.
  2. Select Maintenance.
  3. Select Firmware Upgrade, then follow the prompts to download the latest version of firmware, free of charge.
From Kodak support:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=9104/7269&pq-locale=en_US
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error 2200
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 02, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
What does error 2200 mean
Printer Reset
Mar 07, 2008 | Lexmark P4350 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
