Question about Cell Phones
My Nokia5200 memory card slot is not working and when you switch on the camera the phone will restart it self, so also my mouth pies is not working.
My nokia 5200 slot not show the memory card. and memory card working in another cell.
Posted on Feb 17, 2011
How to fix my sd card showing no sd card
first check is ur sd card working properly. if yes then switch of ur phone for remove batteries memory card sim card and keep it in this state for about 15-30min.clean the slots of memory car simcard etc. then assemble it and try to restart. hope this will solve ur problem
Mar 09, 2012 | Cell Phones
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Camera on standby phone memory full whats a sollution
The phone camera can only function when there is available storage for the image(s). So once it if full, the initial storage location is full, then you do have to create space for new images to be stored before the camera can function properly again.
If your phone doesnt have a memory slot, the means that you are limited to the memory size you use, which is your phone memory.
The solution here is to delete some data on your phone, or transfer it to another device. Then restart your camera.
If your phone has a memory slot, but your dont have a micro SD card in it, get one, then start your camera, go to settings, and change the storage to memory card.
If you already have a memory card, and it is not full yet, it means your camera is storing the images on the phone. Go to settings when you turn on the camera, and change the storage location to memory card.
But if you have a memory card, and it is full, you would have to delete some items to create space.
I hope one or more of the instances was helpful to you?
Have a nice day.
Jul 05, 2011 | Cell Phones
My sd card is locked
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Oct 28, 2010 | Motorola Mobility CLIQ Cell Phone
My memory cards locked I should OPEN my memory cards
Hello
Kind regards
Andrea
Sep 10, 2010 | Nokia 3110 Cellular Phone
Hi guys, when i want to use my camera on my phone i reiseved a mail: Another application is running. Close it and then start the camera. i tried several time to check it out but without succes i...
try taking the memory card out and blow the dust out in the memory card slot.. remove all the unwanted applications.. take the battery out for 10 mins and switch on ur mob again.. it'l work..
Aug 26, 2010 | Sony Ericsson S500i Phone
Internal memory is full
  • Don’t miss a shot if your memory card becomes full—switch to in-camera memory quickly, thanks to the internal memory plus feature
  • 16 MB internal memory[1]and SD/SDHC card compatibility lets you start shooting right out of the box
  • or
  • Connect your camera to your PC !!
  • Either you can go to ebay and buy youre self a usb lead that slots in to the camera on the right hand side, the other end slots into a usb on the tower,and you can then transfer youre data (pictures, movies)to youre computer, enabling you to delete all youre data from youre memory.Leaving you a empty internal memory.
Aug 12, 2010 | Kodak EasyShare M320 Digital Camera
I put my memory card in my camera and it has a message that says no memory card. What do I do
I suggest you to turn off your camera and then turn it on. Or you can also re-insert the memory card.
Thank You.
Aug 02, 2010 | Canon PowerShot SD1000 Digital Camera
How to format my nokia5200 phone and install the software
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First Format your MMC: Menu > Extras > Memory > Options > Format memory card > Yes. Note: It is very important to format your MMC before you format your phone!
Then format your phone by typing *#7370# on main Phone screen.
Phone will ask: "Restore all original phone settings? Phone will restart." Press 'Yes' and enter your Lock code (default is 12345).
You don't need to install the software, it will be there automatically as soon as you format it.
GOODLUCK
Nov 06, 2009 | Cell Phones
I have problem with my memory stick in w850
It should be a problem with your memory card slot in your phone. It could solved by dusting the inside of your memory card slot.
After trying this, please reply whether it worked.
Thank You
Nov 15, 2008 | Sony Ericsson W850i Cellular Phone
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
