Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice maker not making ice
I dont see water coming down the lines to the freezer and the Ice maker itself does not turn
  • 1 more comment
  • Amir1252 Apr 25, 2008
    The model is Frigidaire FRS22ZRF
  • Anonymous May 11, 2008
    My ice maker is not working I am getting water but no ice.
    Thank you
  • Anonymous May 27, 2008
    Our ice maker makes ice, but very slowly. If we fill 3 glasses with ice for dinner, we can not get another full glass of ice for 2 hours.
    Genius:
  • 1,073 Answers
What is the model number of the ref
Posted on Apr 24, 2008
Adora freezer on the bottom not making ice
It could be a couple of things. Check to see if the bar that controls turning the ice maker on and off is in the down position. Up is off. My ice makes water line froze in the refrigerator section; no ice and no clod water. Check to see if the cold water is working in the refrigerator section. If not, turn the refrigerator section temperature to 42, keep the door open until it drops to that temp, and wait 24 hours for the water line to thaw. The water and ice maker should start working.
Jul 12, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Tip
What to do if your ice maker stops working
Many refrigerators now come with built-in ice makers. Ice makers are very convenient, but occasionally they'll develop problems. Why pay a repairman to come out if the fix is easy and you can do it yourself?
Here are some tips for fixing an ice maker that stopped working.
- Check the on/off switch
Freezers with automatic ice makers have a switch that is used to turn the ice-making feature on or off. This switch is typically a rod above the ice box; when it's lowered, the ice maker is on, and when it's raised the ice maker is off. If the ice box fills up with ice, the ice can force the rod up, turning off the ice maker. Check this bar to be sure it is in the lowered position.
- Check if the auger or chute is clogged
Your ice maker has a chute where the ice falls from the freezer into the external tray (where a glass is placed). There is also an auger inside the freezer that rotates to drive the ice forward from the ice box into the chute. Check the chute for large chunks of ice that may be clogging it up, and check the auger for ice cubes or chunks that might have gotten wedged between the auger and the freezer, causing the auger to be unable to rotate.
- Check the water line
If you still haven't found the problem, check the water line leading into the freezer. This water line has its own valve. Make sure the valve is open, allowing water into the freezer to create the ice.
on Jan 23, 2011 | Refrigerators
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
I have water leaking in the freeer apparently down the back wall and pools on floor to form ice. Water has also accumulates under freezer on hard wood floor but not all the time. Model MSD27326R There is...
Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
Mar 27, 2010 | Refrigerators
No longer making ice. no sound coming from the motor if it is trying to make ice.
Hi lots of things to check.
1) are you getting water at door ? - if so water is on and filter is not blocked or installed backwards.
2) this does nor rule out the solinoid because it has two sides one for water and one for ice. ( we will come back to solinoid)
3) Is the ice maker swich turned on ? located inside freezer door to the right of the icemaker looks a bit like a wire coat hanger grab it and push it up for off or down for on ( you should hear a click)
4) Is you fill tube blocked with frozen ice ? located inside freezer door at back of ice maker, looks like a plastic hose going through the back wall at an up hill angle. if so heat it up with a hair drier to melt ice. or pull part out from back of fridge and soak in hot water.
4) Check control board. (This was my problem)Turn off power, open freezer locate a white plastic square cover with sides about 6 inches long, located at front of icemaker prise out the plastic button located on the right side with a flat screwdriver pull white cover off, ( check power is off) look at wheel behind cover if you see any melted parts then this is your problem. remove three screws and pull wheel and front panel towards you it will come away. dont turn wheel by hand - if you need to line up spline turn part in ice maker instead, also note on - off switch ( wire coathanger thing attaches to this ) Top right. sounds harder than it is. sniff part, can you smell a burnt out smell if so order a new part on line. ( this part controls all the action. turns water solinoid on to fill tray, tips tray etc,
5) water solinoid has had it, located at back of fridge behind cardboard, water line from wall attaches to this as does water line to cold water and water line to ice maker, this is a double solinoid so it is posable for ice to work and not cold water or vice versa, turn off water and power remove part and take to your electrical part supplier for testing and or replacment.
Oct 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not making ice GE Profile
First check the temp inside the freezer. If it is not colder that 10 degrees the ice maker will not operate. If it's cold enough make sure the water has not been turned off and that you have water coming to the frige. If you do, inspect the tube where water comes into the freezer and pours into the ice try. See if it is frozen closed. If not, disconnect the water line opisite your water supply on the water valve. Using jumper wires, connect 110v to the valve. Water should come out when you attach the 110v. If not or the tube is frozen that you checked before, either one of these will require you to replace the water valve.
Aug 15, 2009 | GE Profile PSI23NCR Side by Side...
Ice maker not making any ice!
it either is the water vavle burned out or the ice make went out usualy that is a common problem when the line freezes up to test the ice maker there take the front cover off ice maker then there should be two holes in the front a hole that has m and the on next to it put a jumper wire in that hole if it dont rotate the ice maker is bad. or if it is the other kind of ice maker take a flat head screw driver and turn the screw with on the motor gear clock wise keep turning it until it runs on its own you should get the same results like the above if ice maker test good the water vavle is bad check make sure you have no restrictions in the water line take the line off the vavle and let it run in a bucket to see what kind of water pressure you have it should come out fast
Jun 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool ED5LHAXMB11 Refrigerator side by side
check your module itself on the ice maker make sure the plactic piece that turn the motor is not broke off if you can move the injector blades up and down without force that could be your issue to check you ice make sensor open the freezer and push the light switch 3 times you should get a solid red light where you can turn your ice maker on or off if that is not solid it is the computer chips that are in the freezer liner if all that checks then replace the water valve
Mar 11, 2008 | Whirlpool GS6NBEXR Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
