Back to:
Tags:
Casio DBC1501 Wrist Watch
Watch band replacement
posted by Jimz504 on Apr 24, 2008
I am trying to replace the watch band. I a can't get the 2nd side in. Is there a trick to line up the pin with the hole? It is such a tight fit.
Comment by Jimz504, posted on Apr 28, 2008
Great suggestion. Using a small metal file to create the grove works best. My watch is once more where it should be - on my wrist.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 24, 2008
FixYa! (100)
the repman
Rank:Guru Guru
Rating: 88%, 51 votes
If you can, get yourself a small flathead screwdriver and grind or cut out the middle to resemble a barbecue fork. This will help you to hold down and move the springbar. If you can't grind or cut it, just use it to hold down the ledge that springs down (like a toilet paper holder) and push it over with that. It will probably take a few trials, because it is difficult without the right tools.
Rating Locked! (?) Jimz504 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Watch band replacement:
I don't want to Accept this solution
Can you Help with these Watches problems?
Watches
Need watch spare parts
Watches
how do i contact sector repair in Brazil ??
Watches
I have a Colibri Beam Sensor Lighter from 1980 how do I...
Watches
armitron watch band for model M525
Watches
I am looking for links for a DKNY mens watch the style...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
