Question about Optoma EP739 Multimedia Projector
NO Signal, D Sub Source Lock
While I connected this LCD to my computer Ican't get anything with the eception of the above.
4 Suggested Answers
  • 4234 Answers
SOURCE: no signal
The output video needs to be enabled on the laptop. Normally this connector is not active. There should be a function key that has the outline of a CRT screen on it. Using the ctrl key and that key at the same time will toggel the output video connector on/off. If that does not resolve the problem, please update this with your exact setup including cables.
Thanks,
Dan
Posted on May 12, 2008
jahting
  • 70 Answers
SOURCE: Is not picking up the source.
go to the menu and find source setting then unlock.
Posted on Oct 08, 2009
sodeep
  • 3267 Answers
SOURCE: I can't get to the menu to unlock it... and my
The lamp cover has a disconnect feature such that the power wont be activated that it won't allow power while the cover is off. Sometimes the piece of metal gets bent out of place.Try removing the cover for the lamp, and bending the little piece of metal forward.
It worked (in my case) when fiddling with one such piece, dumped in the store, when I was the Hardware *** Network administrator of a govt. sponsored university. I just opened it & then when I could'nt find out Why ??, so just cleaned it and observed this small metallic tag which simply looked like a clip, so I assumed it's a clamp to hold the lamp cover in place when in use.Tried rubbing it to clean it in case its still has enough pliability, by fiddling with with my insulated tester *** screwdriver, without unplugging the power chord !!!!! It zapped my eyes as the lamp got activated wile looking closely at it(a bad habit of mine, just a bit more curious than any cat)....sodeep
Posted on Oct 26, 2009
When i open my camera it shows write protected from after i connected to my computer. can i fix it my self.If ican then how?\
Write protected means the you can only see but you can't add anything to it, in this case it would be your SD card.
Try checking your memory card, there should be a kind of switch on the side, if there is, it must be on "Lock", just slide it up or down, depends on where the lock section is. Try it again.
If it doesn't work, then you must go to the camera's properties, and unblock from here, also make sure the read and write boxes are checked. Goo dluck and hope it works.
Oct 27, 2013 | Olympus LCD Screen Display FE-320 FE-340...
'no signal input'
D-Sub is usually used for input from a computer, make sure the TV's input source is set to Analogue or Digital (or DTV) as it seems to be set to accept input from a computer, if you do not have a computer connected, then this is why it is complaining of no signal. It will not automatically defer to normal TV without being told to do so, have a look in the manual, or guess around the remote control to change the source of the signal.
Sep 14, 2007 | Westinghouse LTV-19W3 19 in. LCD...
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e...
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Mar 19, 2011 | Computers & Internet
Saying no d,sub signal
Ok, Can you confirm that there is connection to the source PC?
If so if that connection is Blue usually means analog (and your Monitor was switched to Digital) Hit the 2 Button to switch back.
If the cable is white, it should be connected to DVI and should be connected to the Digital.
If there is, do we have another monitor to swap out to test from the pc?
As a whole this issue comes down to the PC is not sending a signal to the monitor (either do to a crash on the PC side, or a severed cable..
Feb 28, 2011 | ViewSonic VP201s 20.1" LCD Monitor
DOes someone know what type of lead fits into the back of a daewoo hl711a lcd monitor, and can anyone reccomend a lead that would connect it to an hdmi sourse.
Some digging around google suggests that this screen only has a D-Sub type connector on it, further digging suggests that there isn't anything available that would allow you to connect to an hdmi source.
If the source has any other connections available you may have more luck with them.
Nov 25, 2009 | Computers & Internet
Sub doesnt do anything while plugged in ( Sunfire mk II)
Some subwoofers can sense the signal on their input and will only start when there's enough signal for long enough time for them to turn on the amp.
Try seting the "subwoofer signal out" on your reciever a bit higher, see if it does the trick, if not, try it with some other source (e.g. an mp3 or CD/DVD player) plugged directly into the subwoofer. If it still doesn't work, there's some other problem with your sub (bad connection inside sub, sub amplifier problems, maybe there's another fuse for the speaker itself, try to check it out).
If it works well with an alternate signal source, the problem might be either in reciever or the signal cable that you use, but could also be something else.
good luck
3rq8 (Triarcuate)
Jul 15, 2009 | Sunfire True Sub MK II Subwoofer
Pc connection
Have you pressed the "source" button to cycle through to the "RGB" or "D-Sub" input?
Apr 12, 2008 | TruTech PVS31170S1W 17 in. LCD Television
Tv source
pull the back off the tv and plug in the cable for the input board. Its either not seated or came lose
Oct 02, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Sub-woofer does not turn itself on in 'Auto' mode (signal driven)
For the "auto on" problem.
These will sound very basic, please go with it.
On your signal source, make sure you have the sub set to on.
If you can adjust the output setting on your source, turn this up.
Adjust the volume setting on the sub lower to mach the volume of the main speakers.
You may need to make these adjustments a few times to get them working.
On the hum and noise problem
Check your power outlet for the sub, make sure the polarity is correct. I have found this to not always be right. Also what is on that same circuit. Things like the fridge can cause a lot of noise on the power line. Next check your connecting cables, are they of good quality? Are they running next to anything that may cause interference? Also check you connections to the signal source. Cable and dishes are known for ground problems.
Sep 26, 2007 | Velodyne CHT-12 Subwoofer
Optoma EP739 Multimedia Projector Logo
316 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
