Question about Acer Computers & Internet
When i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the laptop wont startup and no beeping sound.When beeping start the laptop cooling fan get stopped.
  • rajesh_phili Jul 31, 2010
    Are u sure that fan is faulty....
    Problem Solver:
  • 5 Answers
That means that your ram is good..real nice of you to have check that...now see if you can get a spare cooling fan..cause i guess that your fan has reached its limit or heat sink overheated..
Posted on Jul 30, 2010
  • aftab07 Jul 31, 2010
    maybe am rightor am wrong ..in one ad other case i would tell you to check your fan..cause if its faulty you'll need to buy aew one afterall but if not keep it as spare..but i beleive its the fan..if its fsaulty then the logical circuit will trouble up on the beeps..
    Problem Solver:
  • 5 Answers
I've had the same problem w/ 5610. Downloaded the service manual here (http://tim.id.au/laptops/acer/aspire%205610%20travelmate%204200.pdf) and repositioned the keyboard. Problem solved...
Posted on Aug 22, 2010
No beep no display
Do you still see the logo of your computer when you pressed the power button? What is the model of your computer?
David
Jul 13, 2013 | Acer Computers & Internet
Laptop wont power on
Hi yes the laptop will still power on and at least beep at you or light up the LEDs and start the fans, you will get no display with out the ram installed, but you will get a basic power on so listen for those fans,
if you install the ram you should get a a display on the screen with the branding logo and boot information but without the hard drive it will have no operating system
Jun 30, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
MY ACER INSPIRE LAPTOP MAKE BEEPING SOUND WHILE BOOTING.
when i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the laptop wont startup and no beeping sound.When beeping start the laptop cooling fan get stopped.
Oct 27, 2009 | Acer Computers & Internet
Blank screen on my laptop, unit is turned on
Could be a couple of things. First off, I would try shutting the laptop off entirely, removing the AC Adapter and battery from the bottom of the unit and pressing the power button down for about 20 seconds with all devices removed, and plugging everything back in and turning it on again. Should this not work, again remove power and battery, and if you're familiar with the process, removing the RAM as well, then plugging the power back in and try turning it on, see if you can get the computer to emit a POST error beep. If you do get the beep, then it could very well be a faulty stick of RAM, which is easy enough to replace. If you don't get the beep, but the unit still powers on, then there' smore than likely a problem with the motherboard in the laptop. If that's the case, then check with either Acer Technical Support via phone or web, or with the place where you bought the computer and see if you're still within some kind of warranty, and if you are, you can get it serviced through them. If not, motherboard repairs can be very costly (parts and labour will probably run about $400-600USD). RAM modules though like I mentioned before are quite inexpensive and simple enough to replace.
May 08, 2009 | Acer (ACERMOTHERBOARD)
PC (NEC) 4 short beep at start up.
That would be ram or keyboard, but because there are no picture to screen, then most likely its ram.
Try to reseat ram modules,
or if its two modules then you can remove one power on and then another one and power on to determine which one is faulty,
or replace the ram.
Apr 20, 2009 | Dell Latitude C610 Notebook
My Acer aspire 5500 don't power on, it bip continously after centrino logo display
If it is making beeps during the startup (called post for Power On Self Test) this is usually a memory error. You can try reseating the memory chips.
Apr 13, 2009 | Acer Aspire 5500 5570-4421 Laptop
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
Notebook LCD
The screen problem sounds like a leaky capacitor or other failing component that once warmed up exhibits close enough to the correct values to correct the display problem (this usually progressively worsens with every boot of the laptop until no benefit occurs after warm up).
The beeping sound suggests a hardware error, and could be the keyboard. I have seen this on a Satellite and randomly pressing multiple keys on the keyboard momentarily stopped the beeping and allowed the unit to boot (yours seems to be getting past the error beeps on it's own though, suggesting another culprit). The problem could be bad RAM, so pulling one stick of RAM out at a time and starting the computer will eliminate or confirm the RAM as the problem. Other removable hardware such as the hard drive (you would have to install another hard drive to check this one), wireless card, PCMCIA card/device, USB removable hardware (mice, keyboards, wireless antennas, etc...), should be the first devices disconnected to eliminate as being the cause.
Sounds like a real problem child/laptop. Multiple simultaneous problems are always tougher to troubleshoot as they can compliment/effect each other, so look at the one that occurred first. Good luck!
Aug 29, 2008 | Acer Aspire 3680 Laptop
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
251 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
