Back to:
Tags:
Vacuums
Generic problem for all Vacuums
Bissell Powerwash Proheat, flow indicator
posted by num3er on Apr 24, 2008
Bissell Powerwash Proheat, flow indicator not rotating
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 24, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1206 votes
Is it spraying? Is so, maybe the cap for the indictor can be too tight, or loose, maybe be bad and allowing an air leak. The white filter under the indictor may need to be cleaned. If no spray:
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and mater thru it to see if it will unclog it.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Bissell Powerwash Proheat, flow indicator:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Sanyo Permax SC-U125 Bagged Upright Vacuum
I need to replace the hose on the backside of the vacuum...
Rainbow E series Canister Wet/Dry Vacuum
i have the machine connected correctly but it wont spray...
Vacuums
Miele white star vacum cleaner - electrical cord not...
Oreck ElectrikBroom AV-701B Handheld Vacuum
While trying to fix one problem with the AV-701B, I think...
Vacuums
vaccumcleaner spring tube not sucking. bottom trnsperent...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
