Question about Allied Telesyn AT AR410 Router
How to reset Allied Telesyn AT AR410 Router to default factory?
De Guyver
  • 123 Answers
SOURCE: How do I factory default settings
The following is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624S, DI-754, DI-764, DI-774, and DI-784 routers. To perform a reset, please follow steps below: Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset. Step 2 Hold paper clip down for 10 seconds and release. Note: Do not repower unit during this procedure. Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset. Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults. If you have the European version of this router, this procedure may not work. Please consult the D-Link office near you. D-Link USA does not support the European version.
Posted on Feb 16, 2006
sandrew
  • 2961 Answers
SOURCE: Port Forwarding for Allied Telesyn AR725
If you refer to this link, it should explain how to do it for you, best of luck http://alliedtelesis.custhelp.com/cgi-bin/alliedtelesis.cfg/php/enduser/std_alp.php?p_sid=psCY4LAi&p_lva=&p_li=&p_page=1&p_prod_lvl1=5&p_prod_lvl2=63&p_search_text=port&p_new_search=1&p_search_type=3&p_sort_by=dflt
Posted on May 04, 2007
sandrew
  • 2961 Answers
go to this link for instructions, best of luck http://alliedtelesis.custhelp.com/cgi-bin/alliedtelesis.cfg/php/enduser/std_alp.php?p_sid=psCY4LAi&p_lva=&p_li=&p_page=1&p_prod_lvl1=5&p_prod_lvl2=63&p_search_text=port&p_new_search=1&p_search_type=3&p_sort_by=dflt
  • 6 Answers
SOURCE: password recovery on Allied Telesyn AT AR390 Router
I can't find any information on the AR 390 but what I know for sure is if you look on the back there should be a reset button, more than likely in a hole, if you get a paper clip and unbend it to depress the button it will reset everything including the password. You may have to disconnect the power and press the reset button and connect the power while still holding the button in.
Posted on May 01, 2008
XRAYRON
  • 156 Answers
SOURCE: Factory Default Reset Procedure
Hold the reset button in for 10-15 seconds... Now its defaulted back to factory and the user name and pass will both be admin
Posted on May 07, 2008
How to reset to factory default, how to know the ip default.
Default ip: 192.168.1.1
user name: manager
password: friend
Jul 08, 2014 | Allied Telesyn AT Computers & Internet
put a 192.168.1.1 in browser with default user id: manager password: friend
Can't find user and password
Reset your router and login with default factory settings.....Find the default username and password from user manual....
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com
Sep 18, 2012 | Allied Telesyn AT WA1104G Wireless Router...
Forget the default password for ar410
ALLIED TELESYN AT-8024(GB) CONSOLE n/a admin ALLIED TELESYN AT-8024(GB) HTTP manager admin ALLIED TELESYN AT ROUTER HTTP root (none) ALLIED TELESYN ALAT8326GB MULTI manager manager ALLIED TELESYN AT8016F CONSOLE manager friend ALLIED TELESYN AT-AR130 (U) -10 HTTP Manager friend
hope it helps
Jun 22, 2012 | Allied Telesyn AT AR410 Router
How do i reset my at-8000s switch to factory default by using command
follow this step
KIMIA# delete
startup-config Delete startup configuration (Reboot from defaults)
flash:// Delete a file from the flash (flash://filename)
WORD Specify name of file
KIMIA# delete startup-config
<cr>
Delete startup-config [y/n]? y
Startup file was deleted
KIMIA#
User Name:manager
Password:friend
console#
console#
Mar 29, 2012 | Allied Telesyn Allied Telesis...
Router ar 410, wan port is eth0 with statick ip, public, and switch port 1 is on vlan2 with pirvate ip address 192.168.18.253. how tu add default route for acces to internet eth0 is connected on shdsl...
Does the DSL router have a model number? Also for the public address, can you give me the first couple of digits. I just want to make sure it is truly a public IP address and not a class A or B private address because only an ISP can hand out public addresses.
If the IP address on eth0 is indeed private, I am guessing you have to get into the DSL router and set a static route to point to let it know about both of the the ar410 networks on each interface. Keep in mind it might not understand VLSM so when you static route in the DSL to the 192 network you will only need to specify it as 192.168.18.0 as class C default mask is 24.
Mar 01, 2011 | Allied Telesyn AT AR410 Router
Dear, i have allied telesyn 4port rauter, i have change my password. and i forget the password now. please help me soon, what i want to do now?
Easiest way is to reset your router to factory settings which if you hold the reset button in for 30 seconds this should do. Your username and password will both be admin then and you will need to re-setup your router.
Nov 27, 2010 | Allied Telesyn AT AR740 Router
Can reset to default
Try to login in your switch through network connection and then try to do "factory reset" after that you can able to see your switch will set on default.
Mar 30, 2010 | Allied Telesyn AT 8024GB Networking Switch
How to Allied Telesyn Switch password reset?
The Allied Telesis website says this:
How do I recover a lost user's password on Layer 3 Switch or Router? ...
If a user forgets their password, the password can be reset from an account with MANAGER privilege, using the command:
SET USER=login-name PASSWORD=password
Another website has this to say:
device has a reset button.. you can push that via pen, check the devices handbook you will see that mini button..
push that button for a ten second... and release.. your settings will reset.. default username : manager password: friend
Jul 18, 2009 | Allied Telesyn AT-8624T/2M (AT8624T2M10)...
Password router
You can not get the old user name and old password.... you have to reset the router to factory default settings but then you have to make all the settings from scrach.
Jun 15, 2009 | Allied Telesyn AT WA1104G Wireless Router...
Allied Telesyn AT AR410 Router Logo
926 people viewed this question
Top Allied Telesyn Computers & Internet Experts
Prashant M
Prashant M
Are you an Allied Telesyn Computer and Internet Expert? Answer questions, earn points and help others
