My trackball cannot sroll down . its stuckk ..
    Genius:
  • 1,456 Answers
Hi
To unstick your trackball,you need some rubbing alcohol
Pour a few drops of rubbing alcohol directly on your trackball,you can use a dropper to do this.
Roll the trackball around continuously until it starts to work again
Posted on Jul 30, 2010
Blackberry bold trackball goes left, right and down but not up how do I fix this?
This is a common problem on Blackberrys with trackballs. When the trackball goes bad you lose one direction first. Inovagent can replace your Blackberry trackball or you can find another local place to have it done.
Feb 07, 2010 | Cell Phones
Trackball 8800 Blackberry
Your trackball needs to be cleaned. You have two options.
1) You can send it in to be repaired, or
2) You can clean the trackball yourself.
To clean the trackball yourself:
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! (Like you should be during the whole process as all parts have very small plastic nipple which can break very easy.)
When the silver plastic ring is removed you will see the inner trackball component which can be removed completely. Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position.
The trackball component itself can also be carved. For every direction the ball can roll to you’ll find a sensor wheel. Those wheels are mostly carrying some gunk you should clean them from.
Once this is done put everything back together to the place each pieces came from and secure the trackball with the silver plastic ring that you removed in the first step.
Your BlackBerry’s trackball should be back working now.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | AT&T Blackberry Curve 8300 Smartphone
Ball on blackberry wont navigate up or down
Hi. BlackBerry smartphone trackball fails to roll in a particular direction because, debris is lodged in the trackball.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in a desktop computer.
Using for certain period debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
I hope this information will be helpfull.
Nov 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
8220 , trackball wont go down
Trackball doesn't work if you have not selected the sensitivity.
To select the sensitivity, kindly follow the steps:
1. Select menu.
2. Select option.
3. Select screen/key board.
4. Scroll down to find horizontal and verticle
5. Select horizontal-100 and verticle-100.
Oct 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Trackball only moves sideways not down
It sounds like the trackball has become dirty. If you prise of the silver plastic trackball surround, you can lift out the trackball component and give the small rollers at each side a clean.
Aug 22, 2009 | RIM BlackBerry Curve 8310 Smartphone
My trackball on bb 9000 won't move down
good luck.
if you can get the part -- its a trackball assembly btw not just the ball itself
you press down on the silver ring around the ball and turn, the cover will fall out. use a small probe and lift the assembly out.
many times there's fuzz in there -- check it out before you buy a new assembly
Jul 23, 2009 | RIM BlackBerry Pearl 8100
Trackball not working
you need to have the trackball either replaced or service
Jul 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
Sidekick 2008 trackball doesn't scroll down or left anymore
More than likely, the trackball on your Sidekick 2008 is really dirty. Overtime, dirt and grime gets in between the ball and the sensors.
It is really easy to clean it, you will need q-tips and IPA alcohol. No dis assembly is usually needed!
Check out the Video at the following link to see how the trackball cleaning on the Sidekick 2008 is done
Sidekick 2008 Trackball Cleaning Guide
Jun 30, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Blackberry 8830 wont track down - trackball stuck
This is usually caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Apr 16, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
