Hi
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key. This process is different for each computer manufacturer. If unsure which Function key enables and disables the touchpad, try each one at a time and then attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard. The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again. Note: Mac computers use "F2" to enable and disable the touchpad. Please take time to rate me
go to : Canada battery on-line shop,sell Laptop battery, Digital Camera Battery (DC ...... Welcome to buy ThinkPad T42, replacement laptop battery for IBM ThinkPad... https://www.linkme.com.au/groups/public
The Touchpad is pressure sensitive, you can program the Touchpad's functionality. Go to Control Panel, click, to open Mouse Properties. Click the Device settings (block), select the Settings button; after the Touchpad Wizard appear! "View the (left) "Select an item" pane, and click to start the Touchpad's actions." Follow all the instructions carefully. I hope this Fix it
this is not a software driver issue... many IBM and Dell laptops that have the 'trackpoint" aka pencil eraser head between the G and H keys of your keyboard that control your mouse cursor cause this problem
If your laptop has the TOUCHPAD and the TRACKPOINT cheap fix OPTION #1) is to remove the keyboard and cut the ribbon cable that attaches to the trackpoint. Voila ! Problem solved if you never use the trackpoint (most people use touchpad instead anyways) or you can use external mouse as well. Next option is more realistic for most people...
OPTION #2) Buy a new keyboard cheap on eBay. Search: IBM T42 keyboard. Easy to replace. See this link, easy for even a novice http://www-307.ibm.com/pc/support/site.wss/MIGR-46515.html
BIOS password is stored in c-mos battrey...A small battery in the motherboard.....if u take out the battery and put it again.....The password will b lost....and then it won't ask for bios password...
Are you referring to the Atmel EEPROM 24RF08 chip? If so, in the T40 Thinkpad it is under the touchpad, I suspect on the T43 in may also in the same location.
