Question about Samsung NC10-14GW Notebook
No audio device
I don't have an audio device on my netbook my unit is NC10 what should I do? I troubleshoot everything still doesn't work playback, recording and others are all grayesh
    Scholar:
  • 126 Answers
Download the latest sound card driver free here-
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05013600&prd_mdl_cd=&prd_mdl_name=NP-NC10&prd_ia_sub_class_cd=P
install the driver and restart.
//javaftper
Posted on Jul 30, 2010
Testimonial: "Tnx javaftper your advice was very helpfull I got my sound back the only prob is the speaker icon in the task bar is missing how can i have it back? "
  • James Aug 01, 2010
    if you are running Windows XP which I assume you probably are then try the following-
    If it is just hidden then right click on start - properties - taskbar - customize - volume and set to always show.
    if that doesn't work it has been disabled so you will need to go to- control panel - sounds - and check "Place volume icon in the task bar".
    if you are using Windows 7-
    Right click on the start button - click properties - click customise.
    Then next to the volume icon click on the behaviour drop down and select 'icon and notifications'.
    //javaftper
  • rencarlo0630 Aug 03, 2010
    Thanks a lot FixYa Team specially to javaftper, now I got everything I need in my netbook. you deserve the best more power,,,.....
Samsung NC10 - Audio drivers won't install (correct drivers)
Download CCleaner from www.piriform.com/ccleaner. Uninstall the drivers and run the registry cleaner. Then install your drivers. :)
Jun 08, 2012 | Samsung NC10 Netbook
Attempting Computer PC to HDTV hook-uo using VGA/3.5mm auio toconnector box converting to HDMI. The line fromm PC to box is 25 ft. and the line fom box to HDMI plasma TV is also 25 ft. . Computer is...
You need to make sure you changed the sound device properly in windows. To do this right click the speaker in the bottom right hand corner of your screen and hit playback devices. Then select the correct device. If you don't know which you can select one and right click and hit "test". Keep trying them until you get sound out of your TV.
If that doesn't work then make sure you have the latest sound drivers. There are two audio drivers on the Gateway website that might work http://global-download.gateway.com/GDFiles/Driver/Audio/Audio_Realtek_5.0.1.5704_Vistax64Vistax86_A.zip?acerid=633675264897204477&Step1=DESKTOP&Step2=LX%20SERIES&Step3=LX6810&OS=ALL&LC=en&BC=GATEWAY&SC=PA_6G and http://global-download.gateway.com/GDFiles/Driver/Audio/HDAudio_nVidia_1.00.0.37_Vistax64Vistax86_A.zip?acerid=633675265145088477&Step1=DESKTOP&Step2=LX%20SERIES&Step3=LX6810&OS=ALL&LC=en&BC=GATEWAY&SC=PA_6G .Try them both and at least one of them should work. You may need to restart your computer after installing the drivers but after that everything should work fine.
May 13, 2011 | Gateway (6000161) Sound Card
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
I have a samsung NC10. I have connected to my TV via the PC cable. I can see the screen but here no sounds. I have connected the red/yellow/white audio cable to the tv. It has a jack plug on the other end....
The cable you are using is a rca audio/video cable. The colors translate to:
  • red=audio,right
  • white=audio,left
  • yellow=composite video
Your laptop headphone input uses a ⅛′ (3.5 mm) mono and stereo (TRS).
You need a Stereo 3.5mm mini phone plug male to 2 RCA female connectors.
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
Nov 07, 2009 | Samsung NC10-11PBK Netbook
No sound in Samsung NC-10 netbook. In sound and Audio Devices it says no audio device detected. i installed the audio driver (5.10.0.5693). Did not work
If you are running windows XP or Vista and the problem happened recently then you can use the System Restore program to try and take the system back to a date when it was working.
Another thing to try is when the laptop starts up ,the Samsung logo is displayed it should have a message written about to enter Setup press... (press that key to go into setup program).
Look in the sections if there is an onboard Audio section and make sure it's on enabled or auto ,you can change the values by pressing the Enter key when done you must Save and Exit.
May 13, 2009 | Samsung NC10-14GW Notebook
Samsung NC10-14GW Notebook Logo
386 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
