Question about Harman Kardon AVR 230 Receiver
No firmware after power failure
I lost the software after a power failure on my AVR 255/230
I have tried downloading up date software from your web sight
But when I click on software I end up on a page of manual
downloads ??? no software??
SO WHERE DO I GET THE SOFTWARE
I have been on this computer all day trying to find this software
The real annoying thing is this happen a year ago but I have lost the download software
Can you tell me where to look and the web sight will have this software
  • 928 Answers
I really have no idea if this si a computer or something else.
If it's a laptop, you should have a partition with the software already downloaded, all you have to do is a restore to factory using the partition. It is called D2D.
Again, if it's a laptop, and you have no idea what I'm talking about, then I recommend that you take it to a professional, they will fix it without downloading the software.
Posted on May 15, 2017
4 Suggested Answers
SOURCE: Harman Kardon AVR 7000 loosing memory
This is what's in the AVR7000 service manual:
Subject: Backup Memory on AVR/DPR/HK series receivers.
In the event of the complaint: “the receiver is losing its memory (any programmed system settings)
when the unit is turned off, or after the unit is unplugged (briefly*)”:
Check and replace:
Model: AVR7000
Designator: C730
Description: 0.047 Farad 5.5v capacitor
Part number: # P10790-ND or # J3432147324X
I'm having the same problem and this is how far i got so far. I don't kwow how to get and replace this part.
Posted on Nov 16, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
  • 6771 Answers
SOURCE: My Harmon Kardon AVR 2600 goes to protect mode when powered up. After many tries it will fire up but at times it's up to twenty times. I did load the software upgrade 6 months and it has been fine
Check all speaker wiring for shorts, if okay! there is a problem in the audio output stage of the unit or the protection circuit is not working properly. I would suggest a pro to evaluate.
Posted on Apr 03, 2012
I have a denon avr-400 receiver. When running a firmware update, i got the error message: Connection fail:03. Now, my receiver is not working. stuck in this endless cycle of failure messages. Help
Unfortunately a failed firmware update will result in an inoperative unit. The solution is to update the firmware directly to the chip. Not a DIY solution. A local Denon repair center will be equipped to do that for a nominal fee. Your unit is a bit older to get much help from the main company.
If you are handy you need a chip burner and the proper setup and then force the firmware onto the chip. Lot of computer guys may have that around to help.
Good luck
Jan 16, 2015 | Denon Avr-5800 Receiver Ad, 4 Pg, 2000,...
My iRiver H10 will not power up
Hi Ozzieange.....the most common cause of this symptom for your specific player is that it's set on "hold". Ensure that "hold" isn't selected. If this hasn't resolved your issue, and you are using Microsoft as your OS, let's begin by updating the applicable software for your OS, released on 08-08-07 by clicking on the following URL: http://www.iriver.com/support/down_view.asp?searchProductIdx=61&searchCategoryIdx=3&searchString=&page=1&idx=860&tmpSearchProductIdx=Select+a+Product&tmpSearchCategoryIdx=Select+a+Category&tmpSearchString= Download and install the above software, and finalize the installation process by restarting your computer. Once restarted, let's update the firmware on your Player by clicking on the following URL: http://www.iriver.com/support/down_list.asp?searchProductIdx=61&searchCategoryIdx=1&page=1&idx=&tmpSearchProductIdx=61&tmpSearchCategoryIdx=1&searchString= Click to Download and Install the following Firmware: H10 Firmware Release V2.53 (dated Jul 05, 2006) If applicable, return to the above URL and click to Download and Install the following Firmware: [MTP] Iriver Firmware Updater V2.6.0.0 for MTP devices (dated Jun 22, 2007) Once these tasks are successfully completed, your Player, and the neccessary Software for your computer to properly communicate with your Player are now current and fully functional. Please return to update your post with your progress and/or observations.....good luck my friend
Aug 09, 2007 | iRiver H10 MP3 Player
Forgot password for Craig CMP741e tablet. tried to reset factory settings (holding on button with volume button) but wouldn't do anything
The only way to fix this is by restoring the firmware. There are two different firmware loads for that tablet, depending on the manufacture date. You can download the firmware for the older CM741E from the web site, but the newer firmware you can to get provided by Craig.
You will either need to make a bootable MicroSD card using Phoenixcard, or use a special software called LiveSuit to push the firmware into the tablet.
Oct 06, 2013 | Tablets & eReaders
My denon avr 1312 does not start. the power butten is red but not flashing. display off. no reaction whatsoever. any ideas?
unplugged the unit and do these reset
if these have already been done, and symptoms persist
the unit needs servicing.
Aug 20, 2012 | Denon Avr-1312 Home Theater Av A/v...
I have lost the software for my Nikon D40 camera.Model n16184. I want download the software.
This is the Nikon support web page that has the firmware updates for your camera. Current Firmware downloads available for Nikon products Nikon... The D40 is near the bottom of the list. Follow the instructions carefully.
Jan 24, 2012 | Nikon D40x Digital Camera
Software
The link below points to the nikon USA download page, you can download manuals, software and firmware there.
This is waht the page says.
Welcome to the Nikon Download Center. Keep your Nikon products up-to-date; download product manuals, Nikon software and firmware (the software that is embedded in your digital camera). Firmware updates for your digital camera will help maintain your camera’s performance. Please note that some of Nikon’s downloads require an account log in ID. http://nikonusa.com/Service-And-Support/Download-Center.page
Jul 21, 2009 | Nikon COOLPIX L10 Digital Camera
49 2f81- error
From the service manual:
A critical firmware error has occurred. This type of error can be caused by invalid print commands, corrupt data, or invalid
operations. In some instances, electrical noise in the cable can corrupt data during transmission to the MFP. Other causes include poor quality parallel cables, poor connections, or specific software programs.
To fix:
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs, disconnect all of the cables that
connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
To upgrade firmware:
The MFP has remote firmware update (RFU) capability. Use the information in this section to upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software. This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
This procedure requires that you install HP Web Jetadmin Version 7.0 or later on the computer. See Using HP Web Jetadmin software. Complete the following steps to update a single device through HP Web Jetadmin after downloading the .RFU file from the HP Web site.
1 Start HP Web Jetadmin.
2 Open the Device Management folder in the drop-down list in the Navigation panel. Navigate to the Device Lists folder.
3 Expand the Device Lists folder and select All Devices. Locate the MFP in the list of devices, and then click to select it.
If you need to upgrade the firmware for multiple HP LaserJet 4345mfps, select all of them by pressing the Ctrl key as you click the name of each MFP.
4 Locate the drop-down box for Device Tools in the upper-right corner of the window. Select Update Printer Firmware from the action list.
5 If the name of the .RFU file is not listed in the All Available images box, click Browse in the Upload New Firmware Image dialog box and navigate to the location of the .RFU file that you
downloaded from the Web at the start of this procedure. If the filename is listed, select it.
6 Click Upload to move the .RFU file from your hard drive to the HP Web Jetadmin server. After the upload is complete, the browser window refreshes.
7 Select the .RFU file from the Printer Firmware Update drop-down menu.
8 Click Update Firmware. HP Web Jetadmin sends the selected .RFU file to the MFP. The control panel shows messages that indicate the progress of the upgrade. At the end of the upgrade
process, the control panel shows the Ready message.
HP Web Jetadmin is a Web-based software solution for remotely installing, monitoring, and troubleshooting network-connected peripherals. The intuitive browser interface simplifies crossplatform
management of a wide range of devices, including HP and non-HP printers. Management is proactive, allowing network administrators the ability to resolve printer issues before users are affected. Download this free, enhanced-management software at www.hp.com/go/webjetadmin_software.
To obtain plug-ins to HP Web Jetadmin, click plug-ins, and then click the download link that is next to the name of the plug-in that you want. The HP Web Jetadmin software can automatically notify
you when new plug-ins are available. On the Product Update page, follow the directions to automatically connect to the HP Web site.
If installed on a host server, HP Web Jetadmin is available to any client through a supported Web browser, such as Microsoft Internet Explorer 6.0 for Windows or Netscape Navigator 7.1 for Linux. Browse to the HP Web Jetadmin host.
Replacing the formatter
1 Slide the formatter cover toward the left side of the MFP and remove it.
2 Remove two thumb screws (callout 1).
3 Slide the formatter toward the left side of the MFP, and then remove it.
NOTE Dislodging the formatter might require considerable force.
I hope all this information helps! Thanks and please take a moment to give this solution a rating of fixya.
Feb 17, 2009 | HP LaserJet 4345mfp Printer
I lost my webcam cd installer
Logitech, like most CE vendors, has all of their installation software, firmware, device drivers and firmware available on their website - usually in the Support section. Here's the link.
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en
Aug 11, 2008 | Microsoft Office Outlook 2003 for PC
Firmware upgrade failure
Try this for the reset
First turn the unit off then
hold down the "Pure Direct" and the "Direct" buttons on the display at the same time. And while you are still holding them down turn the unit on with the power button on the display.
this should reset the microprocessor.
You will need to put all custom settings back in.
Let me know if this helps.
Dave
Jun 06, 2008 | Denon AVR-3805 Receiver
Harman Kardon AVR 230 Receiver Logo
90 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
