Question about HP LaserJet 2840 Printer
I am getting the message 50.2 fuser error, turn off then on again. Turning off then on again does not solve the problem
    Champion:
  • HP Expert
  • 202 Answers
Ur fuser or power supply may be faulty first replace the fuser ur problem will be resolved
Posted on Jul 30, 2010
Getting an error code 50.9 "fuser error" went through the steps in the help screen and turned printer off/on. Help!
A 50.9 fuser error is one of the most common errors. If you get a 50.x error, you can try turning the power off and on and reseating the fuser but in almost all cases you will need to replace the fuser.
Do not forget to rate my answer
Lucas
Jul 07, 2011 | Office Equipment & Supplies
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
I get a printer error message: "50.2 Fuser Error Turn off then turn on." I have done that but I get the same message again and again .. Could you help please ?
I not sure what machine you have, if you can inform us that would help at little bit, as to find you a part number. However what this 50.2 is telling you is the fuser is bad. You can re-seat the fuser, and the connections to the fuser. Most likely you will need to replace the fuser.
What does the fuser do?
The fuser, fuses or bonds the toner to the paper at a very high temperature.
Jan 14, 2011 | Office Equipment & Supplies
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | HP LaserJet 4 plus Printer
Error message
It's the fuser. You can try turning it off, wait 30 seconds, and turn it back on again.
If the problem continues, call a technician in to get the thermistor replaced.
It's a common error.
Aug 04, 2008 | Ricoh Aficio SP C811DN-DL Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
Error code e000014-0000
This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
Nov 02, 2007 | Canon imageRUNNER 5020 Copier
HP LaserJet 2840 Printer Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
