Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
I am interesting about "sleep command" @ distance device.
Is it existe and how can I set it.Thanks./Question is't about tech-problem,I know, but it is my problem/.Thanks.
    Problem Solver:
  • 19 Answers
You question your existence, a common question to which the answer you will find within yourself.
Posted on Jul 30, 2010
How to change fitbit flex device sleep settings to sensitive?
Great question!! Any luck going into settings on your computer to see if there is an option for that?
Jul 26, 2014 | Fitbit Flex, Set of 3 Swappable Wristbands
Tip
Windows Vista : System not coming up from Sleep Mode.
Disable Hybrid Sleep Mode in Windows Vista Windows Vista has a neat new feature for laptops called “hybrid sleep”. Actually, Windows Vista has a neat new feature for laptops called sleep too, so I’m getting ahead of myself a bit.
Windows used to have a fairly simple hardware suspend command called “standby”. However, this operation took a while to execute (both entering and exiting standby) and it was somewhat unreliable when performed repeatedly, on certain hardware or with certain applications running. Sleep is meant to alleviate these problems by just serializing the current state into memory and then shutting down all devices other than the RAM. With the OS state simmering in memory like that, entering and exiting sleep is nearly instantaneous. However, the dark side to all this is if there is a power outage while the computer is in sleep, all of the unsaved data is lost (since it just existed in memory). That’s where hybrid sleep comes in.
Hybrid sleep saves the OS state into RAM, but it also writes it all to the hard drive as well (sort of like hibernate does). This ensures that even if power is lost, the data will remain. This all sounds like a good idea, but in practice it’s just as slow as standby was.
Now, laptops have batteries and most of them are configured to enter hibernate when the battery dips below a certain level. This means that unless the battery is physically removed, power to the RAM is never unexpectedly cut. Thus, we don’t really need the hybrid sleep feature. Unfortunately, giving hybrid sleep the pink slip is a little harder than it could be.
Step one, open up the power options setting from the control panel and select the “Change plan settings” link below the selected power plan.
Once in the resulting dialog, choose “Change advanced power settings”. Now you need to scroll through the miles and miles of options to find the “Sleep” node. Expand this, and then the “Allow hybrid sleep” node below it. You should see two options, “On battery” and “Plugged in”. Set both of these to “Off”.
Once this is done, click “OK” and you should be all set! From now on, whenever your laptop would normally go into “Sleep” – usually when the lid is closed or when inactive for a certain time – it will enter full sleep mode, rather than hybrid sleep. And when you go to awaken it from its slumbers, it should be fully responsive within a second or two of reactivation – as opposed to the 10-15 seconds after hybrid sleep.
on May 28, 2010 | Computers & Internet
Computer will not go into sleep mode
The following few steps would probably solve your problem:
1)You'll need to open Control Panel. To make things easier, type in "power" into the search box, and then click on "Power Options". (for command line hackers, you can just type powercfg.cpl,1 in an admin mode command prompt and get right to the good stuff)
2)In the resulting screen, click the "Change plan settings" link underneath the currently selected plan.
3)In this screen, click "Change advanced power settings".
4)Now you'll need to browse down to Multimedia settings \ When sharing media.
5)Change both of the options to "Allow the computer to sleep". The menu item for Sleep should be back to normal.
Please let me know if this works.
Jan 11, 2011 | Gateway DX4720-03 PC Desktop
On Zebra 105Se printers, what is the a command line to allow label length calibration (2-3 labels used), but not sensor sensitivity adjustment (which wastes so many more labels). I know it exists, as...
The line is part of the ZPL (Zebra programing Language) set and can be downloaded at http://www.lancerlabels.co.uk/zplcommands.pdf
The command you want is on page 187.
Jan 14, 2010 | Zebra 105SL Thermal Label Printer
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
My HP LCD screen keeps going to sleep.
ur comp has an estimated time set by the company which is 20 mins if ther is no activity on the comp it goes to sleep wht u ave to do is go in device manager and uncheck the box in display frm advance option in tht way ur comp will never go to sleep dont know if u will understand this not good at typing working for tech supp for hp used to talking no typing
Aug 25, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hi, my G5 won't "sleep" either by a direct command or after its assigned wait period.
If you have aftermarket third party USB or Firewire devices plugged in it may not sleep correctly. Try unplugging non Apple stuff and restart if it sleeps you can narrow down whats causing it. Go into control panels and set sleep to like 1 min to test.
Jun 24, 2009 | Apple iMac G5 MA064LL/A Desktop
I have heard that there is an upgrade to the Magellan Maestro 4040, where you can actually speak to the device and get things like directions to the closest resturant. How do I get this upgrade if...
Upgrade your Magellan Maestro with hands-free Voice Command & Control for the easiest, most satisfying navigation experience.
Your Maestro 4040 will respond to your voice commands to give you quick information and an instant route to nearby points of interest. Activate Voice Command & Control and find the nearest coffee, food, gas and ATM simply by speaking. Ask for your current location and distance to destination and hear the details as you keep your hands on the wheel and your eyes on the road. Just say the word and get instant information about the nearest roadside assistance.
Purchase the upgrade and you will be given a unique unlock code. Enter the code* into your Magellan Maestro 4040 and let your voice put you in command
Apr 16, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
I-Mate K-jam having a 'spaz'
Hello, you can ask imate's tech support. They respond immediately. just email them at [techsupport@imate.com]
Mar 29, 2007 | Griffin Technology iMate - Universal ADB...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
