Resatore ur hardware & software configuration and install reginout i hope it will fix ur problem
This message: "NO HARD DRIVES HAVE BEEN FOUND" has probably shown as you have a problem in data cable of your HDD (try to plug it harder on both ends. Computer shouldunplogged from power). If this not works try change the data cable.
Another solution might be to check the sata configuration in post boot. (Right after computer boots there is a message telling to press a key to configure booting)
Third solution would be to check the jumpers on your hard disk
Power on the Bluetooth Hardware you want to connect to the computer. You must have some sort of hardware to connect to the computer, in order to enable the Bluetooth connection.
Click "Add" and the computer searches for any Bluetooth hardware in the area. Once it detects the hardware, select it and click "Next."
Type in the passkey for the Bluetooth hardware (found in the device's user manual) and click "Next."
Install any drivers now that came with the Bluetooth hardware. (Insert the driver installation CD that comes with the Bluetooth hardware, wait for the the installation wizard to load onto the screen, accept the license agreement, then click "Next" for the installation name and location and select "Install" to install the drivers.)
Choose "Locate and install driver software" if there are provided drivers. If not, click "Don't show this message again for this device" and click "OK."
hope this helps
