Question about HP Office Equipment & Supplies
I have 1 problem in my hp4400 printer when I send print command to print 1 copy then I find that my printer print 2 copy insteed of 1 copy ?
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Lexmark s605 won't make a copy
Check settings from computer, try to send command from computer to scan and copy. May have to plug usb cable in to access all settings unless it's wireless only.
Apr 01, 2014 | Lexmark Office Equipment & Supplies
Will not print
try to restart your computer. before u print something, make sure u select the right printer (maybe there's copy 1, copy 2, and so on), check the usb cable, and don't turn on your printer before the laptop/pc ready because your computer will not able to detect the printer if you turn the printer first.
Jun 13, 2012 | HP Photosmart 4180 All-in-One Printer
My HP4400 keeps saying "out of paper" but there
just let me know that the message is shown when u try to print the paper or it showing the message when u start the printer. Reply with eloboration raaj_k001@rediffmail.com
Jan 13, 2011 | HP Office Equipment & Supplies
Want to print text messages from cell phone
Try sending any test messages to your email address using your cellphone. Then you can print anything using the email's Print operation. The more expensive alternative is to buy the cellphone's cable-to-USB for your model cellphone.
If your phone has bluetooth, send the text to your computer via bluetooth, then use your printer to print them, if you have a bluetooth enabled printer just send them straight to that, or if you don't have bluetooth at all, use a usb cable to connect to your computer.
To access the phone's SMS messages, just click the SMS entry on the left side of the PhoneView window. You can copy individual messages, Command-click to copy several messages (helpful when you want to copy just those messages that are part of a particular conversation), or copy all messages by selecting one message, pressing Command-A to select them all, and clicking the Copy From mobile phone button at the top of the window.
Nov 24, 2010 | Computers & Internet
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
How to change the density of the printer HP LaserJet 5p
I'm afraid this won't be of much help to the original poster, who asked the question a year ago, but anyway - others may be looking for this too, just like I did...
To change the print density, a simple command must be sent to the printer. This is done in two steps:
  1. Create a file, containing the command
  2. Send it to the printer ("copy" it to the printer, in a DOS shell)
The command is:
<ESC>%-12345X@PJL DEFAULT DENSITY=4
where <ESC> represents the "Escape" character (character code 27). There are several ways to generate the Escape character (which cannot be directly entered in a text editor): E.g. substitute the character with any other, save the command and then replace the first character with 0x1b using a hex editor.
Or:
  • Open a DOS window
  • Enter:
    copy con density.txt <Enter>
  • Hold the <Alt> key
  • type 27 on the numeric keypad
  • Release the <Alt> key - the Esc. char. is shown as ^[
  • Type the rest of the command (e.g. %-12345X@PJL DEFAULT DENSITY=4) - adjust the density value to the one you actually want to set.
  • press <Enter> <ctrl-Z> <Enter> to write the file
When you have successfully created the command file, send it to the printer. In the DOS window, enter:
copy density.txt LPT1
(assuming that your printer is connected to LPT1)
That's it!
To verify that the density has actually been set, print a printer status page.
The printer remembers this setting, so this needs to be done only once.
Mar 31, 2009 | HP LaserJet 5p Printer
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at Zebra.com
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
