Question about Sharp AR-153E Copier
Void copy viod copy.check main charger and transfer gud
  • Sharp Expert
  • 1,326 Answers
Have replaced the developer? I don't remember if the copier toner is the developer unit. Did you just put a new toner in. If so, you may have a defective cartridge.
Posted on Jul 30, 2010
Toshiba e studio 283 error c970
https://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%20283&code=C970
C970
Description
Process related service call High-voltage transformer abnormality: Leakage of the main charger is detected.
Causes
Remedy
1. Is the main charger installed securely? 2. Check if the spring of high-voltage supply contact point is deformed. 3. Check if the needle electrode is broken or the main charger grid is deformed. 4. Check if any foreign matters is on the needle electrode or the main charger grid. 5. Check if the transfer roller and the separation needle are installed securely. 6. Check if the transfer roller or the separation needle is removed. 7. Check if there is any foreign matter attached on the transfer roller or the separation needle. Toshiba Studio 283 Error Codes
Apr 06, 2018 | Toshiba Office Equipment & Supplies
How to clear code c970 toshiba 456
deformed.
grid is deformed.
installed securely.
removed.
Jul 19, 2016 | Toshiba E-Studio 456 Copier
TOSHIBA 1370 WILL NOT COPY. PUT IN NEW INK CARTRIGE, CLEANED CHARGER a AND b WHATS NEXT?
f white copies appear on your toshiba impression.
replace the corona wires main loading and transfer, do not forget to check the development unit if turevelador is too old replace
Feb 24, 2015 | Toshiba 1370 Black and White Copier
HOW O I VOID A TRANSACTION?
what kind of machine is it?
Oct 24, 2014 | Retail Supplies
Dirty copy result even if i replace a new drum
There are small wires that charge the drum to transfer image. Not sure if they are in drum unit or not on this machine. If the transfer chargers are dirty they will cause a dirty or voided copy. Make sure document glass is clean. Unplug machine check for these small wires if dirty gently clean with cotton swab or soft towel. Hope this helps
Mar 02, 2014 | Kyocera FS-1135MFP Copier require feeder
Call for service C97
[C97] High-voltage transformer abnormality
(1) Is the main charger installed securely?
(2) Check if the spring of high-voltage supply contact point is deformed.
(3) Check if the needle electrode is broken or the main charger grid is deformed.
(4) Check if any foreign matters is on the needle electrode or the main charger grid.
(5) Is the transfer/separation charger installed securely?
(6) Check if the transfer/separation charger wire is broken or unhooked.
(7) Check if any foreign matter is on the transfer/separation charger wire.
Jan 07, 2018 | Toshiba e-STUDIO182
ERROR C970 TOSHIBA E STUDIO 350
[C970] High-voltage transformer abnormality
(3) Check if the charger wire is broken or the main charger grid is deformed.
(4) Check if any foreign matters are on the charger wire or main charger grid.
Oct 02, 2012 | Brother HL4040CN Laser Printer
Copy darkness problam
Change the toner, transfer the charger or the primary/main charger
Jul 24, 2010 | Canon imageRUNNER 2870 Copier
Copies have a void area the length of the copy approx 1 inch wide
pull out your toner unit and look at the front to see if there is a missing spot on the roller where there is no toner. if not you probly need a new drum.
Nov 12, 2008 | Sharp AL 1631 Copier
Mita dc 1860 copy machine
Check Drum from scratches,check cleaning blade.Also check Heat roller.
Nov 15, 2007 | Office Equipment & Supplies
Sharp AR-153E Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
