Question about Maxent Televison & Video
P58h10nja cant set up chanels to program.i get as far as tv tuner setup menu. i cant start auto search in air or cable
  • Maxent Master
  • 19,396 Answers
Hi.
First ensure that cable or antenna are connected properly to the input of the TV panel.
The issue can be firmware or a defective imaging board (this includes tuner).
Call Maxent at the number listed on the owners manual to know if any firmware update is available. There is no firmware for this model available on web, and installing wrong firmware will damage the TV.
If there is no update, or if the update does not fix the problem, then the imagin board must be replaced.
A good alternative to the repair is purchasing and connecting an external set top box available for a small fee.
See also:
Maxentusa.com
Maxent YPWB11592SMPP Imagin Board
Posted on Jul 30, 2010
I need to reprogram my zenith sy2568s tv to recieve available channels
With the remote control:
1. Press Menu repeatedly to view the Setup Menu. 2. Select Auto Program. 3. Use the Left/Right Arrows to advance to the next menu. 4. Select either OFF AIR ANTENNA or CABLE TV.* 5. Use the Left/Right Arrows to advance to begin the channel search.
*NOTE: THIS TELEVISION WAS MANUFACTURED IN 1996 AND HAS AN ANALOG TUNER ONLY AND WILL NOT RECEIVE OVER THE AIR SIGNALS AS ALL OVER THE AIR SIGNALS ARE DIGITAL NOW AS OF 2009. IN ORDER TO USE THIS TELEVISION SET FOR OVER THE AIR SIGNALS YOU WILL NEED A DIGITAL TO ANALOG CONVERTER BOX AVAILABLE FOR BETWEEN $30 AND $60. CHECK EBAY FOR GOOD DEALS ON THEM.
Apr 23, 2011 | Zenith SY2568S TV
We can't get any of the channels don't know where to start from menu area
Hello
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press UP or DOWN buttonTo AUTO TUNER SETUP
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
PROGRAMMING OVER
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
Nov 29, 2010 | JVC AV-27120 27" TV
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
Can't receive channels above channel 28
Try doing a " auto tuner setup" from the set up menu,
Select "Menu" from the remote and step through to "Auto Tuner Setup" choose CABLE or AIR and press "START". when done message will appear.
Jan 03, 2010 | JVC AV-32D305 32" TV
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
I can't acces auto chanel search,how can i fix this?
To get that option you have to change the source to Tuner..
Press the source button on your remote or on the tv until you see tuner on the screen..Then press menu and down arrow until you see "Setup"
Jun 10, 2009 | Syntax Olevia 537H Television
Tv tuning instructions how to?
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto
Channel Search
Auto Cable/Air Switch sets tuner
to cable or “off-air” frequencies
during initial setup. Then system
automatically scans for and locks
active channels into channel
memory.
May 06, 2009 | RCA F32648 32" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Frozon at chanel 25
Go into the setup menu and redo the tuner setup. It will ask you if it is over-the-air (regular) TV or cable and then it will do a scan that searches for channels.
After that it should work.
If not, you will need service.
However, you may be able to get around a bad TV tuner by using another tuner, such as cable tuner or in your VCR to provide the channels. To do this use another input on your TV or select channel 3 on your TV.
Hope this helps :)
Mar 31, 2008 | Televison & Video
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Televison & Video Logo
85 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
