Question about Gateway M1200-3004265 Tablet PC
Motion m1200 i was wondering if anyone helped you on your touch screen problem. I'm having the same problem. Please let me know if you found anything out about it
First be sure that you are running windows XP tablet edition, then download the drivers from motion computing. This is the link:
http://www.motioncomputing.com/support/driver_download_1200.asp
If you are running windows XP regular not Tablet PC edition it is not going to work, toush pad and buttons only work on tablet edition.
This solve the problem.
Posted on Sep 10, 2008
Tablet will power up but has no touch screen
Defective digitizer (a thin layer of invisible material placed just below the glass that senses the figure) in most touch screen devices.
Five things you should know before trying to fix smartphone or tablet...
Aug 07, 2016 | Tablets & eReaders
A cracked screen
I have found new screens for the Kurio 7S, however I do not believe that anyone is selling the LCD screens for the 4s at this time. If is only the front glass that is broken, these can be found on Ebay.
Jan 03, 2014 | Techno Source Kurio Kids Tablet With...
I need a system restore disk on my Gateway Motion Computing M1200 Tablet. Help!
Hey nick, have you tried to buy one from motion customer care, I bought one for around $20
Jan 25, 2011 | Gateway M1200-3004265 Tablet PC
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
Pin does not work when touched to screen.
The stylus has a AAAA (yes, QUAD-A) battery in the body of the stylus - if this is dead, then the digitizer won't recognize the pen. That sounds like what is happening - the batteries can be found at bigger Radio Shacks or ordered online.
Oct 22, 2009 | Motion Computing LE1600 Tablet PC
Operating System Not Found
Hi and welcome to FixYa,
Almost always, your described problem indicates a hard disk problem: either it is no longer recognized (most likely) or the partition / files are corrupted.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Gateway M1200-3004265 Tablet PC
Free download of above driver
What is the serial number of your gateway computer? http://support.gateway.com/support/drivers/dlcenter.asp?cmpid=topnav enter it in here and select the drivers you need.
Thanks,
ArmyMason
Feb 25, 2009 | Gateway M1200-3004265 Tablet PC
Tablet CX 2620 Display problems
You should angle the screen towards the light to see if you have a faint image on it. If so, the problem is more than likely a failed inverter, or CCFL lamp on the LCD itself. Either in which would have to be replaced. The CCFL lamp unfoutunatly part of the LCD it self and cannot be replaced seperate the screen. The inverter can be replaced easy as it it right under the screen. Symtoms of a failing CCFL could be the white comes out as red on the screen for the 1st 10 sec or so of startup. This will put alot of stress on the inverter causing the inverter to overheat and shut off. I have one to where the CCFL failed and am trying to find a replacement.
Good luck
May 18, 2008 | Gateway M1200-3004265 Tablet PC
Upgrading a Gateway M1200 to a M1300...
You can replace any motherboard, so long as your processor and memory are compatable and it fits into your case.
Mar 02, 2007 | Gateway M1200-3004265 Tablet PC
Need touchscreen drivers for Gateway M1200. Hi there I recently bougth a Gateway M 1200 Tablet PC. Unfortunatly I did not get any operating system or drivers and has not been able to use my touchscreen. ...
I just bought one of these used, It had a fresh intall of windows XP tablet. When I got it the touch screen would not work. I have tried dowloading the drivers. I download Motion dashboard for this model. When I open it is says" Dashboard can not be run on this computer" I dont know what to do??
Dec 17, 2006 | Gateway M1200-3004265 Tablet PC
Gateway M1200-3004265 Tablet PC Logo
273 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
