Question about Nokia 2730 Cell Phone
How i set time at the top right of the mobile???
Apps when wifi not available
Have mobile data on your phone plan .
activate mobile data on the phone.
at the top of the screen put your finger on the top of screen and slide down.
Samsung phones have a hidden setting window
then slide finger from right to left as mobile data option just slightly off the screen.
you will also notice a location option. maps needs this to be on to locate your gps position
Aug 15, 2016 | Samsung Cell Phones
The display does not show, so i can't program the unit.
  1. Go to Settings on your mobile device Menu.
    Select Developer Options.
    To the right at the top of the screen is an On/Off virtual switch. Move the slider to On. There will be a check-mark pop up if it is turned on.
To turn on the USB Debugging on a Samsung 4.2.2 or higher
  1. 1
  2. 2
    Click More Menu.
    It is located in the upper right area of your screen.
  3. 3
    Click on About Phone
  4. 4
    Now, at the Android Build Number on your Samsung mobile device tap seven times.
    This will activate the Developer Mode.
  5. 5
    At Developer Mode select Developer Options.
  6. 6
    Tap the USB Debugging.
    It will turn on, and a check-mark should pop up to the right of USB Debugging.
Mar 25, 2016 | Breadman Kitchen Appliances - Others
Can't connect Samsung GT-S5620 to internet
Samsung phones have a hidden settings screen at the top of the screen on the normal screen
pull down the top of the screen by placing finger at top of screen and swipe down
and expand the hidden settings you will than see wi-fi , location, sound,screen rotation, blue tooth, put finger on right top of screen and swipe left you then should see
Mobile Data at left top of screen
put finger on mobile data and it should turn on mobile data
Apr 25, 2017 | Cell Phones
How to set the time
Hi cglines,
You can set the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Mar 15, 2011 | Timex 1440 Nylon watch
How do i set time
Hi rwhit41,
Hope it helps.
Cant set ringtone on samsung m1
to set a ringtone to a contact you go to the contact you want then press pencil in top right then ringtones then scroll up to user selected ringtones then sounds then music select the song you want then tick in top right then go back with arrow in top left then take your pencil out. hope this helps. good luck
Jan 05, 2010 | Cell Phones
I just bought a Diesel Dz 7094, and apparently setting the date and time on Diesel watches are always confusing and the manual never helps. I am having a hard time and I can't get the time set. Please help...
Press the bottom left button 3 times to enter the setting mode. The 'seconds' will begin to flash.
Press top right button to reset 'seconds'
Press the bottom right button to get to the 'minutes' setting
Now press the top right button to advance to desired 'minute'
Press bottom right button to get to the 'hour' setting
Then press the top right button to advance to desired 'hour'
Then press bottom left button to complete.
Feb 20, 2009 | Watches
SET THE TIME
: 1. With the time and date showing, press the top left button. 2.Press the right top button (this sets seconds) 3.Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm). 4.Press the bottom left button, minutes flash. Press the top right button until correct minutes. 5.Press the bottom left button, month flashes. Press the top right button til correct. 6. Press bottom left button, date flashes. Press the top right button til correct. 7. Press bottom left button, day flashes. Press right top button til correct. 8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished). To turn off the chime and alarm, press the top right button repeatedly until the CHIME or CH symbol is gone, then press the left top button. Repeat for alarm but watch for the bell icon or ALARM or ALM to disappear, then press the top left button.
Feb 16, 2008 | Columbia All Sport watch
How to display the date on my home screen
just press the menu botton'
go to setting
sellect initial set-up
and select time and date.
you can now set the time and date of your fone...
Jan 05, 2008 | Motorola Mobility RAZR V3
Nokia 2730 Cell Phone Logo
90 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
