Question about Dishwashers
When turned on second light comes on, stays on, and beeps-CDW 1211
  • ljshort Jul 30, 2010
    Thank you! You're a STAR! Problem seems fixed.
  • 19,396 Answers
Hi.
Disconnect the power cord and check the faucet at the back. If lights are still on, then disconnect, and connect back the appliance. Check faucets and inlet hoses at the back before connecting back.
Posted on Jul 30, 2010
  • 3 more comments
    Thankyou.
    Have done this. Water is coming to inlet ok.
    Problem still the same- light beeps ,water to inlet ok.
  • Ginko
    Ginko Jul 30, 2010
    Hi.
    Check if there is water inside the tub, and check if the high level float switch is stuck. Do this operations with power off.
    Try restarting the appliance (connecting back) with cycle in position 2.
    Also please confirm model, I assume this is a Conia CDW 1211.
    Yes Model CDW 1211 Conia Dishwasher.
    How do I find and check sensor. The bottom was very ful at first but empty now and pump out is working.
  • Ginko
    Ginko Jul 30, 2010
    Hi.
    I do not have precise schematics for this model. I the float sensor is inside the tub, I think at right hand side, at the bottom. If machine is draining and there was water, then that is not the problem.
    Re: The bottom was very ful at first but empty now and pump out is...
    That means that there was a drain problem. Check drain hose at the back and drain well. Remove well and clean. Do all this with power off.
    If the pump is working, then the problem has been probably caused by blockage.
My ps3 slim 320 GB wont stay on. red light comes
You have a mother board failure and your system needs to be serviced.
Aug 29, 2013 | Sony Playstation 3 (PS3) Console
Monitor randomly goes black
saet monitor to never sleep
Feb 03, 2013 | Computers & Internet
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
May 19, 2011 | Plantronics CS70 Wireless Headset
Wehn i turned on after 30 seconds make five bips five times
Does your airbag light work? It should come on and stay on a few seconds after you turn the key on. If it isn't on, then the beeps mean the light is out. I've seen people take the light bulbs out when they sell the car so you don't know there is an airbag issue because the light would stay on. This is illegal and if that bulb is missing, you may be able to get them to repair it.
Nov 18, 2010 | Ford Expedition Cars & Trucks
Car makes loud noise when i turn it on
This beep is coming from the waring module, the 1st one is the seat belt test beep, it is norman and last a few seconds, the last may be normal as well, how long does the headlight warning stay on?
Nov 14, 2008 | 1999 Volkswagen Passat
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Kia brake beeping
brake pad warning light pads need changed
Aug 17, 2008 | 2002 Kia Sedona
Conia cdw 1211
Had same problem - tilted dishwasher forward 45 degrees & let water drain out - it now works fine.
Aug 01, 2008 | Dishwashers
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
