Question about Cell Phones
Voltage of Philips CD 130 AC/DC adapter? Can some one help me plz I got the Philips CD 130, but i lost my power adapter, what adapter (output voltage) I need?
techbuster
  • 5081 Answers
SOURCE: I lost my charger and
Input to an charger is 100-240V/50-60hz/125mA
Output is DC -5.7V/500mA
Posted on Oct 30, 2010
Benimur
  • 6966 Answers
SOURCE: AC/DC Adapter
Hi, You would need an adapter that puts out 12 Volt DC, Output Current: 3.3 Amp and the Center Positive Power Tip (Output Power: 40W). The original ViewSonic adapter is M/N: UP06031120A Hope this be of some help/idea/ Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 13, 2007
SOURCE: ac adapter voltage
Usually it is 5 Volts and 12 Volts Generally also it is DC not AC. on a standard connector for the power it is 12V 0v 0v 5 V. Hope this helps
Posted on Jan 30, 2008
SOURCE: Compaq Presario V2000 no power new dc jack
I had similar problem, the power pin soldering has gone bad. I removed the cover and soldered it back, its woking now
Posted on Aug 06, 2008
patreg
  • 152 Answers
SOURCE: dell power supply ADP-220AB B output schematic
It may be possible that your adapter does not receive the rated power it should receive. You may have plugged your adapter to a 110 v outlet when the required input is 220 volts. See your adapter for the specific requirements.
Posted on Oct 26, 2008
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
Which AC adaptor to use with New Balance Elliptical 9.0e
if u have a lot of ac adaptor then find thesame voltage output to ur gadget..if you don't have the exact voltage dc output for ur gadget better buy one....what is your machine need? ac power or dc power? if your machine is electronicaly operated so u need is dc power...but if your machine is like a motor so u need is ac power....tnx
Jun 19, 2012 | Computers & Internet
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Cannot find power adapter for mms171w philips system. Needs AC/AC adapter with 10v ac at 1.8 amps output. Cannot find aftermarket counterpart either. Help. Lost adapter while moving.
What does the other end of the adapter look like?
Is it a conventional circular one or is it a special port like it's thin square like or USB like maybe?
If it's conventional any 10v 1.8amp or 2 amp output should do and a lot of them are available in e-bay or if there's a Best Buy, Staples, Etc near you can just drop a visit purchase one and it should work like a charm.
However if it's not a conventional adapter you may have to contact philips and purchase one that is compatible from them.
Hope this shed some light on your problem!
May 31, 2011 | Philips MMS171 Computer Speakers
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
Input voltage ?? lost power supply WHP-150C
the adapter is a thomson output is 19v-200ma--neg polarity
Apr 30, 2008 | RCA WHP150C Consumer Headphones
Tv and pc monitor
Hi, your best bet is to get a LCD/laptop universal adapter from ebay like this one: http://cgi.ebay.co.uk/Universal-AC-Laptop-Notebook-LCD-Monitor-Adapter-NEW_W0QQitemZ250172562395QQihZ015QQcategoryZ64471QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
 Do a search for the one that is cheapest and nearest to you. These come with lots of different heads and voltage is variable so you can just adjust it to you needs.
Hope this helps. Si :)
Oct 12, 2007 | Philips Magnavox 27MS343S 27" TV
AC/DC Adapter
Sep 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Cell Phones Logo
447 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
