Question about Nokia 5200 Cellular Phone
Nokia 5200 replacement facia
Hello, I want to change the cover fascia on my Nokia 5200, but all replacements come with tool kits, what do these do and how do i take the phone apart to replace the front, back and key pad? Thank you Ian Jackson
  • concal Apr 28, 2008
    hi, I want to change my facia but dont know how to please help
    Sergeant:
  • 154 Answers
Sir,
If you do change or attempt to open the cover of your phone or ANY other parts that will act as disassembling the phone and this will void the warranty.
If you really want to change the cover of your phone, do this:
By a 5200 cover of ebay or any website with your desired choice of colour,
Take it to a Nokia Service Centre, give them the cover and they will change it for you.
heres the link, i know it says Nokia repair, but they are the only official people who can change it. for you.
www.nokia.co.uk/repair..
or view this video file which shows how to change...
http://video.aol.com/video-detail/nokia5200-cover-changedutch/2907686820
surely this would be helpful to you sir.. thank u.. dont forget to vote me..
Posted on May 03, 2008
Disassemble Miele fascia panel and control
There' s three reasons I can think of for removing a facia plate.
1- replacing a damaged original
2- accessing the control module
3-changing the language
On older models you may have to unplug the unit and remove the top to access screws that hold the facia housing. Then remove the housing to access the facia.
On newer models the screws were placed under the facia so the techs' don't have to remove the top.
Use a plastic paint scraper thin enough to get in between the facia and the housing. Pick a spot along the top or bottom and push straight into the gap. You can only go in about 1 mm until you stop. While still holding pressure inward pry the tool's back end away from the facia - up if your in the top edge or down if your in the bottom edge, until you access the inner step of the housing. Once your tool slips past the step, slide the tool left or right to find the locking tabs and pop them open. The facia will bend a bit. Watch that you don't drop it or it may scratch. The first is the hardest so be vigilant.
If you bought a new Miele Facia panel you should call their customer service support team. That's what they are for. They will be glad to guide you by telephone.
If your just curious to see what's underneath don't bother, unless you like looking at mounting screws for the plastic housing.
Nov 07, 2014 | Washing Machines
How to remove the rear bumper cover on a pontiac 2004 grand prix
  1. Open the trunk.
  2. Remove the rear compartment sill plate. (Trim round the back edge of the trunk)
  3. Pull the left and right compartment side trim panels down to access the fascia bolts and nuts.
  4. Remove the tail lamps.
  5. Remove the fascia bolts and nuts from the rear bumper fascia 1 nut 1 bolt on each side near tail lights.
  6. Remove the push-in retainers from the top edge of the fascia.(4 plastic circles, pull up on center of cirle with screwdriver
  7. Raise and support the vehicle.
  8. From underneath Remove the push-in retainers from the rear bumper fascia (one on each side I think)
  9. Remove the fascia bolts from the rear bumper fascia. on on each side from, up where the facia connects to the quater panel)
  10. Remove the rear bumper fascia from the vehicle
Apr 14, 2011 | 2004 Pontiac Grand Prix
How do I change the headlight. The owner's manual says to remove the 2 hex bolts from the headlamp assembly. I did that. Then it says to remove the 2 plastic fasteners from the fascia & pull the...
its part of the bumper --didnt specify vehicle do online search -----year make model how to change headlight ------and will usually find instructions and or youtube video
Aug 26, 2017 | 2006 Chevrolet Cobalt
How to change full cover on nokia E71? step by step guide
Nokia E71 Housing Fascia Replacement Faceplate Cover, Restore your ... or alternatively use the corresponding tools to change it by yourself.) Package include: Full Housing Replacement Cover for Nokia E71
Full Housing Replacement Cover for Nokia E71 (Grey) * 1
Front Cover
Back Cover
Middle Cover
Keypads
Accessories as the picture shows
Keypad *1
T6 Screwdriver and an opening tool
Aug 12, 2009 | Nokia 6085 Cellular Phone
Nokia 5310 fascia replacement
Here is a guide a wrote for replacing the front housing on a nokia 5310. It should be what you are looking for.
Nokia 5310 Front Housing Change
Hope that helps
Sep 21, 2008 | Nokia 5310 Cellular Phone
FACIA
If you have the new facia cover it is easier than you think. Take a flathead screw driver and gently start lifting the facia up from the key pad.
May 23, 2008 | Nokia N73 Cellular Phone
Nokia 6310i facia replacment
at the top of the phone their is anouther screw it is located top left near aerial, release this and you will be able to seperate phone fascia
May 22, 2008 | Nokia 6310i
N76 fascia replacement
here's what your looking for just watch this
the upper block....
the lower block....
peace!
Nov 26, 2007 | Nokia N76 Cellular Phone
INSTRUCTIONS TO REPLACE NOKIA 6233 FASCIA HOUSING
Yes i own 1 myself and have replaced the case 5-6 times , so here you go :
First you will need a t7 torx screwdriver , and then you remove the screws ( you can find the 2 screws were the battery is )
Once you remove them you can now take the rest of the case of BUT  , you might need a case opening tool for the part just above the battery , after that youve done it except for where the keypad is , replace the keypad and the chrome surrounding the screen you can simply take it off , Hope i helped :D
Oct 18, 2007 | Nokia 6233 Cellular Phone
Nokia 5200 Cellular Phone Logo
135 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
