Question about Honeywell Anti-Theft Digital Steel Wall Safe
My batteries have died today appparently and the key to open it is of course inside the safe
  • 19,396 Answers
Hi.
Contact Honeywell at number listed on safe owners manual. After checking your details they will send you replacement key.
In US please call customer service at: 800-832-5834, rest of the world, see website or manual.
See also:
Honeywell Central.com - Safes & Security Boxes
Anti-Theft Safes - Honeywell AU
Posted on Jul 30, 2010
Need to open a Sentury safe key pad only the batteries died
without knowing the model the best i can doe is link you to you tube and some of the fixes there. i used this search term how to open a sentury safe key pad only batteries died. you may try other terms to get different videos on how to do it. good luck.
https://video.search.yahoo.com/search/video?fr=crmas&p=how+to+open+a+Sentury+safe+key+pad+only+the+batteries+died%3F#id=1&vid=1b6eaea93a88d9929e8b1ce283d04996&action=click
Oct 23, 2017 | The Home Security
I have a Namson SFT-25EA electronic safe, batteries dead, can't remember where I stored key, can I get into it and be able to re use or do I need to force my way in
A "Trouble key" has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
Feb 15, 2017 | The Home Security
I got an offer to buy a safe called safewell No 13119956, her batteries are from inside, digital & key? let's say the batteries died how can i open it?? please any help?
is the safe closed? if not I would write the numbers with key code and put it in a safe place so will remember when its closed and then I can open it.
Jul 22, 2015 | Home Security
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
I AM USING GODREJ E SWIPE ELECTRONIC SAFE, SINCE LAST DAY IT WAS FUNCTIONING PROPERLY. BUT TODAY WHEN I TRIED TO OPEN IT AND JUST INSERTED PASSWORD ITS NOT OPENING. POINT TO BE NOTED THAT THE PASSWORD IS...
Is the battery dead?
Has someone tried to get into the safe causing the keypad to "freeze"?
Have you tried the "Emergency Manual Override" also know as the key? I hope the Emergency Manual Override Activation Device (the key) is not stored inside the safe.
Dec 05, 2014 | Computers & Internet
Bunker hill safe #91006 the batteries are dead and I do not have the key
You are going to love this answer.
I have two Bunker Hill Safes. I bought them at the same time. The batteries in both of them died at the same time. And like a dummy, I had the keys to each safe inside themselves.
So, after going to many forums and looking at videos on youtube. I found the solution and it worked. I now have the keys for the two safes in my combination safe. (no batteries on that one)
Here it is:
1) Get a soft rubber mallet (a hammer with a rubber tip works best) And of course, you can get those at Harbor Freight where you bought the safes.
2) FIRMLY tap the safe, just ABOVE the key board panel, and on the plastic cover. You must be hitting the top of the door and not the body of the safe, in order for this to work. (The locking mechanism internally will bounce up when you do this.)
3) At the same time, you must try to turn the knob/dial, that opens the safe. It will take a few tries to get the timing down, but it works.
On my first safe I did scratch it up a bit and crack the plastic housing a little. On the second safe it did it perfectly and left no marks on it. After doing that I was kind of freaked out on how "secure" these safes really are.
But how many people are going to know this.
Now I change out the batteries every year on my Birthday.
Good luck!!
Apr 18, 2013 | Check Point Network Adapter
Safewell safe EX2007316659 batteries dying and can't open
I have had zero success in finding out any information about various models of electronic safes--no manufacturers' website, no online manuals, etc. Many of these safes are imported from overseas manufacturers.
Dead or dying batteries is a common problem, and I gather that many models of safes come with an override key.
It is incredible how many people have found the best place to keep their override keys and/or instruction manuals is INSIDE their safe!
I ask that anyone with owner's manuals or instruction sheets please publish them on this website for the benefit of others, but that is unlikely as they aren't the ones seeking information--they already have it!
Sorry I can't be of more help!
Nov 10, 2011 | Locks & Locksmithing
I have a bunker hill safe #93575, the battery is getting low. is there any thing i need to know about changing the batterys
Change batteries ASAP because if your batteries die you will be unable to get into the safe without the key. The batteries are located inside the safe. If you can't open the safe, you can't replace the batteries!!!
There are NO replacement keys available for model #45891. We've tried. I would NOT buy this safe again for these reasons.!!!
Nov 08, 2011 | Check Point Network Adapter
I need a replacement key EX2005138875 for my Safewell electronic safe. The batteries have failed and I cannot open the door.
I was locked out of my Honeywell safe after battery died. I ordered a replacement key from firstalert.I was required to photocopy the receipt and type out an witnessed affidavit stating I own the safe. About 3 weeks later I found my spare key,4 days after that the replacement key arrived in the mail ($10.95 money order for that key). The other two spare keys were in the safe, I did not think the batteries would die so soon. Crappy factory batteries that came with the safe.
Mar 15, 2011 | Locks & Locksmithing
My Bunker hill safe Batteries died and the keys are inside.
Check this out:
http://www.fixya.com/support/t1062111-bunker_hill_safe
(no need to re-invent the wheel, other experts have given solutions first)
Sep 17, 2009 | Check Point Network Adapter
Honeywell Anti-Theft Digital Steel Wall Safe Logo
211 people viewed this question
Top Honeywell Home Security Experts
Marvin
Marvin
Steve
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
