How to fix a thermostat on a White Rogers brand thermostat
    President:
  • 1,515 Answers
Hi, there are many types of White Rodgers thermostats, mechanical 1f56-444 models for heat and cooling, digital, heat-pump stats, ect. When a thermostat goes out, or there is a problem with one, its time to replace them. It is something that techs do not repair do to the circuitry, they are checked to see why they are not working properly, and if they can't be corrected by changing out the batteries or an adjustment, we replace them as the contacts where out along with the circuitry depending on the stat. It would be cheaper to buy a new one then try to repair one even if you could find a place that would even take this on to be honest with you. If you know for sure it is your stat, just replace it. Be sure to mark all wiring connections and colors that are being used on a paper diagram, and take the old one with you to get one to match or the style you like. They are priced from $20.00 on up. I hope this has been of help to you and ask that when rating me, you will be kind as I know you will.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Jul 30, 2010
The temp says it is 87 but its wrong
1ST MAKE SURE THAT ITS NOT MOUNTED IN A BREEZY PLACE (NEAR DOOR/WINDOW) , THIS WILL MAKE IT READ WRONG ALL THE TIME , IF ITS MORE THAN ONE DEGREE OFF THEN IT WILL NEED REPLACED , IF ITS BRAND NEW IM SURE WHITERODGERS WILL TAKE CARE OF SWAPING IT WITH YOU
Nov 11, 2015 | whiterodgers White Rogers 7-day...
Gas boiler white rogers need a relay white rogers 8a03a2
contact the manufacture or manufacturers distributors or authorized service agents to get the part
if they are not handy then take the part into an electrical wholesale shed and they may have a replacement part for you
after all white rogers will not make relays but will use brands off the shelf on their assembly line
Oct 19, 2015 | Heating & Cooling
WHITE ROGERS THERMOSTAT
Hey, did you ever figure out how to fix this?? Mine is doing the same now.
Dec 02, 2012 | Shaw Robert RS-9420 Thermostat
Connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
Oct 15, 2012 | Heating & Cooling
White Rogers digital thermostat displayed "lo".
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Sep 24, 2012 | Heating & Cooling
White rogers manual
Hello my name is Heath it will be my pleasure to assist you. There are many models of white rogers thermostats I would need t know the model to get the correct manual.
Oct 08, 2010 | Heating & Cooling
Auxiliary light was lite on my white-rodgers 1f82-51 thermostate and i have no heat?
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise
the setpoint above room temperature. Within a few
seconds the thermostat should make a soft click
sound. This sound usually indicates the thermostat
is operating properly. If the thermostat does not
click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
Mar 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
231 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
