My lenovo 3000 g430 doesn't get any display as processor fan is still working. I tried with an external monitor problem arises same.
  • 20 Answers
Check your memory try cleaning the contacts using an eraser and place it back to your system. If still it doesn't boot up check you video card you may have a bad video card.
Posted on Jul 30, 2010
Use External Monitor for Lenovo Old laptop
Choosing your monitor is more of a personal taste and budget then anything when using one as an external monitor to a laptop. Only issues you might run into if finding the correct resolution to match up to the monitor. This could require a driver update to allow higher resolutions for the monitor to take advantage of its larger size. Max resolution for your laptop is 1280x800 if equiped with the intel 4500 graphic chipset. Also from a quick lookup of your laptop it shows you have a HDMI output along with the standard VGA. Using the HDMI output with a monitor with HDMI input will give you the best picture quality plus HDMI cables are plentiful and a wide range of lengths are available..
May 05, 2014 | Lenovo Computers & Internet
Lenovo 3000 n200 0769AMU press power on switch green light on after about 1 sec screen still black no HD light fan running
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard that usually cause this issue. I wrote a tip on how to do the power drain. Try to plug in external monitor on the VGA port and see if you are getting display using external monitor. If you are getting display using external monitor then the problem would be the laptop LCD. If you are getting the same black screen using external monitor then the problem is already the motherboard.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 19, 2011 | Lenovo 3000 N200 0769 Intel Celeron 530...
I' using lenovo 3000 g430,the problem is my bluetooth and wireless can't on.....i've try to switch on the wireless switch at the bottom of the laptop and then press the FN F5 a thousand times but still...
try to instal the driver again...
dis amble the w lan module..
clean the golden the yellow area with thinner or alcohol wait until dry and plug in again to the mini pci-e slot
change the wi fi module..
i had lenovo 3000 g430 too but i had no Bluetooth installed there? i there any Bluetooth on lenovo 3000 g430?
Dec 31, 2010 | Lenovo 3000 Y410 Notebook
Hello Experts, This is Viswanath Esikala from Bangalore(Near Bomallanali) Iam facing one problem, in lenovo 3000 G430, Problem is when i swicth on button,lenovo laptop is unable to display screen,...
There's a possibility that the problem is with the LCD cable or the LCD itself. If its either one of them, you will not be able to fix that by yourself since you will need to replaced the part itself. But there's one simple solution that may fix the problem if its not the hardware itself.This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Nov 25, 2010 | Lenovo G460 Laptop Computer 06774CU Intel...
My laptop model is lenovo 3000 g430, as my laptop is turned on the screen goes on blinking....pls help me...tell me the solution.
1. Check your power cord & adapter. 2. If its working then check the battery, reseat the battery & check. 3. If available then check with another battery 4. If no, then remove the battery & switch on the PC in AC mode. 5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. 6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. 7. If still no display, connect an external monitor, check if display is comming. 8. If Display is coming then your LCD need to replace.
Aug 23, 2010 | Lenovo Computers & Internet
Mine is lenovo g430.i use windows 7.the system doesnt switch on.the indicaters and the fan comes on and stays.but nothindg is displayed on screen.
Try to perform power drain first as initial troubleshooting.
Procedures:
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30 secs
Put the battery back in
Plugged in the power adapter
Turn on the computer
If same issue will happened call our technical support department to have your laptop checked and scheduled for repair. This issue would be an LCD problem.
By the way. Is your unit still under warranty?
May 21, 2010 | Lenovo 3000 N200 Notebook
Iam using a lenovo notebook 3000 g430
the problem could either be the port or your headphones. try to check if your headphones are working on a different computer; if they are, try hooking a set of external speakers on the audio port of your g430. if you don't hear any sound from the external speakers, then the problem is with the port itself. check if your computer is within warranty; if it is, contact lenovo technical support
Apr 07, 2010 | Computers & Internet
Can i upgrade my lenovo 3000 g430 cpu with the intel quad core extreme processor
No. But you can upgrade your RAM to maximum value to get more speed and efficiency.
Jun 22, 2009 | Lenovo 3000 V100 Notebook
Computers & Internet Logo
79 people viewed this question
Alun Cox
David Payne
David Payne
