Question about Lexmark X8350 All-In-One InkJet Printer
How do I reset the ink level on my lexmark x8350?
How do I reset the ink level on my lexmark x8350 whether I'm using a manufacturer cartridge or refilled cartridge?
  • Lexmark Master
  • 6,826 Answers
Http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark how do I reset the ink level on my lexmark x8350? - pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed.
Posted on Jul 30, 2010
Reset ink levels
Please note that once a Lexmark cartridge is refilled, it can no longer register its ink level.
Also, Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark.
Feb 21, 2012 | Lexmark X Office Equipment & Supplies
Poor print quality
Make sure you are using genuine Lexmark cartridges. Lexmark products work best with original supplies. Lexmark does not recommend the use of refilled, re-manufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Check your cartridge ink levels. From the printer operator panel, go to Maintenance > View Ink Levels. Replace the cartridge that has low ink level. If your ink levels are still substantial for printing and you are using genuine Lexmark supplies, please contact Lexmark Technical Support Center for further assistance.
Dec 28, 2011 | Lexmark X9350 All-In-One InkJet Printer
Refilled ink printer. still shows empty on the printer,s screen
Lexmark does not recommend the use of refilled/remanufactured cartridges. These tend to degrade print quality and printer/cartridge performance.
Please note that once a cartridge is refilled, it can no longer register its ink level.
Sep 13, 2011 | Lexmark X8350 All-In-One InkJet Printer
How do I change the ink cartridge in my Lexmark X8350 printer?
Here's the instructions (Click Here) on how to install or replace cartridges on Lexmark X8350.
Here's another (Click Here), open the link and scroll down to Page No. 4.
If you have problem, let me know.
Good Luck.
Thanks for using FixYa.
Dec 13, 2010 | Lexmark X8350 All-In-One InkJet Printer
Had the cartridge filled instead of buying a new one. I was told at costco that the printer sometimes shows low ink when it's filled to check the manual there is an option that needs to be changed. I...
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Another thing which is mentioned at their support site is quote:
If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
If you find my answer helpful, please vote. Thank you!
Nov 16, 2010 | Lexmark X8350 All-In-One InkJet Printer
It says cartridge error #1203
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 17, 2010 | Lexmark X8350 All-In-One InkJet Printer
I CAN NOT RESET BACK THE INK LEVEL REGISTRATION ON CANON W6200 PG
Please let me know whether its a refilled cartridge or a Lexmark brand genuine cartridge.
Oct 17, 2009 | Office Equipment & Supplies
Lexmark X2530 won't accept re-inking of cartridges
This is a trick that is used on some of the HP printers. Try this, you will need at least 3 maybe 4 cartridges. The printer stores the chip ID in memory for the last 2 or 3 cartridges installed, so, take an old cartridge number 1 and install in the printer, reset power. Next step, take old cartridge 1 out and install old cartridge 2 in, let it come to ready or tell you to replace empty, then install your refilled cartridge. You just have to remove from its memory the chip ID of the refilled cartridge. You can fool it by doing this each time you refill. Can't guarantee this will work with lexmark, but it does work with HP.
Hope this helps,
Printdoctor
Dec 20, 2008 | Lexmark X8350 All-In-One InkJet Printer
Ink levels
on the printer reset the ink levels and in the sofware , otherwise the cartrige is to old and just wont register correctly
Oct 08, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Ink level reset
if you are useing a refilled cartridge , ink cartridge has a chip built in that must be reset, if you look on line you can purchase a reseter. if you use a new ink cartridge it will show a full ink level
Jan 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X8350 All-In-One InkJet Printer Logo
1,337 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
