FixYa.com
Tags:
Motherboards
Generic problem for all Motherboards
Failure to boot up (by 2 users)
posted by tibballs on Apr 24, 2008
I failed to re-insert a 256mb PC2100 DDR Dimm into its slot correctly. The computer booted up the first time but with obvious consequences. I presumed I had burnt out the slot and moved the memory to another slot. The computer booted up fine the first time but then refused to boot up again. Moved the memory to the third and final slot only to have the same rigmoral. I have replaced the memory but the computer booted up the first time and now won't boot up at all. Same situation every time - can hear it powering up but it never actually boots up with nothing on screen. Wondering if I've burnt the processer out or what else would allow you to boot up first time but not second time?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 17, 2008
computer powers up, screen blank no bleeps no bios ,nothing but the fan and the lights work
Solution #1
posted on Sep 01, 2008
Not Rated (0)
babu602
Rank:Apprentice Apprentice
Rating: 81%, 4 votes
I find a very good site for Intel Motherboard Solution.Try the site clickhere.
Please Rate me if this information helpful for u.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 24, 2008
Not Rated (0)
redrivera
Rank:Wiz Wiz
Rating: 84%, 96 votes
if that ram you inserted is just an additional to your existing memory, then chances are that you have damaged the newly inserted ram. if that is the only ram you are using and you thought maybe inserted it incorrectly, it should not have worked even for a while. moving it from one slot to another and the same thing happens? i think your memory should be ok but you better check your mainboard now. otherwise check also the memory you got, what is the operating voltage. see if you're ramo is compatible with your board.
Provided by NORTON STAFF
Solution #3
Not Rated (0)
early1234
STAFF
Rank:Guru Guru
Rating: 86%, 480 votes
try to use another memory asides that one. if you are still apprehensive about it, try to make a general cleaning on the motherboard. check if there is anything burnt, bulging capacitors and the ike...
try to reseat all the ones on the pci slot and re connect all ide cables connecting to your drive and hard drive...
now check if youre still having the same booting problem...
1 more thing, try to reset the bios...to do this, check eith your manual about jumpers...
This Problem Also Relates To: HP Compaq Motherboard HP (P2074-69003) Motherboard Acer AOpen AX4BS-V (91.89J11.001) Motherboard AOpen Olympus 64Mb xD-Picture Card (AX4C MAX II) Motherboard AOpen (MX4SGI4DN2PRE) Motherboard ASUS K8N4-E Deluxe Motherboard ASUS Intel 440BX Chipset P2B Motherboard
Can you Help with these Motherboards problems?
Intel D865GBF Motherboard
no display
monetor ok supply ok prosaser... Answer This...
Matsonic MS9317E Motherboard
usb1
when i tried to connect the... Answer This...
Foxconn 945GZ7MC-RS2H Motherboard
Foxconn mobo
i have just put in a new mobo... Answer This...
Sis SIS741GX-MN Motherboard
KOB845Gx mother board driver
hi, i need KOB845Gx mother... Answer This...
MSI P6NGM-FD Core 2 Quad Socket 775 1333MHz...
unknown device
acpi\ifx0102\1 driver required Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
