Question about Mercury Electronics KOB 630e CFSFx Motherboard
How to replace SDRAM to DDR
My mother board is kobp4m266 ndfsmx sd ram is working how to replace to ddr ram is their any jumper settings.
give sug
regards,
shareef
  • Mercury Elec... Master
  • 27,725 Answers
Sdram has two slots in the module where as ddr ram has only one and there are no jumper settings
Posted on Jul 31, 2010
Istall the ram but do not desplay ram is out of socket and than buzzer 3 bip I was install Ram to other mother board Ram is ok please solve the problem
It is the wrong speed ram for the other motherboard for instance 133 sdram, 100 sd ram, pc2700 ddr ram, pc3200 ddr ram etc. you will have to see what type of ram is acceptable in your new board.
Feb 15, 2010 | Intel D845GLLY Motherboard
Switching Between SDRAM & DDR Slots
All of those jumpers are either currently on or off. If you are switching RAM from SDRAM to DDR, you need to swap all of them. There appears to be 11 sets of jumpers. They are basically like 10 normal jumpers all stuck together as one piece. Move them all over, and switch your RAM, and you're set!
May 07, 2009 | Computers & Internet
Problem for ecs m810d
it's between ddram n sdram connector.
Apr 03, 2009 | PC Chips M810DLU (M810DLUV75C) Motherboard
D865GSA intel mother board supports DDR1 or DDR2 ram
Straight from intels web site...
Two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR 400, DDR 333, and DDR 266 Support for up to 2GB of system memory
Mar 09, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Ddr not detected
if you want to use ddr ram with p4vmm2 mother bord you must replace the jumper near by the ddr2 slot
then your computer starts to work with ddr ram at 266Mhz also 400 Mhz too.
Feb 09, 2009 | EliteGroup P4VMM2 Motherboard
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
Upgrade of ram
Your board Support 168-pin SDRAM DIMM and 184-pin DDR DIMM (Can't Use DIMM & DDR SDRAM memory Together).
I would run the 184-pin DDR. Supports PC1600/PC2100 DDR DRAM up to 2BG Max. Since you have four memory slots 2x512mb of DDR PC2100 = 1GB would be plenty. You will notice programs load faster & games run smoother. Personally, 2Gb. may help but you will not see the difference. To see a difference it is not all about memory. Mb bus speed, CPU, chipset & speed of video memory all play a part with regards to Pc overall speed. You can download your manual here.: http://www.jetway.com.tw/oldweb/evisn/download/manual/index1.htm
You can download the specs of your board here.:
http://www.jetway.com.tw/oldweb/evisn/product/amd/v266b/v266b.htm
And below is a link for some good ram.:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=302039&CatId=548
This should all help you decide, best wishes!
Please vote.....
Jan 23, 2008 | Jetway V266B Motherboard
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
P4VMM2 Motherboard problems with RAM Cards changing fron SDRAM to DDR
Depending on your version of motherboard, it may only take ddr when you change the motherboard jumpers, as i assume you have 2 SDRAM and 2 DDR slots, but you will need to refer to your manual
Apr 10, 2007 | EliteGroup P4VMM2 Motherboard
Mercury Electronics KOB 630e CFSFx Motherboard Logo
65 people viewed this question
Top Mercury Electronics Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Mercury Electronics Computer and Internet Expert? Answer questions, earn points and help others
