Question about Nokia 5310 Cellular Phone
How could i charge my nokia 5310's battery ???????? i have no charger at all
    President:
  • 2,559 Answers
The only way to do this is purchase a charger for it,unless u have another phone that the battery will fit in and then you could just use the other phone and charger to charge the battery.
Posted on Jul 30, 2010
Charging problem
The battery may have to be replaced, especially if you have had the phone for a couple of years
May 31, 2013 | Nokia 5310 Cellular Phone
My nokia 5310 is freezing at starting up from off position to on and then would not be switched off again,until disconnecting its battery. and when trying to charge the battery there is no symbols...
guys if your xpress music phine doesnt start completely..this is what you must do...
remove sim card/mem card
put the charger atleast 1 minute to recharge the battery ...
after 1 min. remove the charger and open your nokia phone it will start completely ..its proven just try it..
Apr 14, 2010 | Nokia 5310 Cellular Phone
I am getting a message that the charger for the 5310 is not suppo
the charger of your phone is either beginning to malfunction or the charging port.
To know where the fault is coming from, use another charger to charge your phone and if the message still comes up, then you should know that the phone charging port is not good and needs to be replaced.
But if the message does not come up, then you need to change the charger.
I hope you got the message.
Best wishes.
Jan 10, 2010 | Nokia 5310 Cellular Phone
NOKIA 5310 not charging? i already replace a new battery and check the power adapter,,(thanks for helping sir brukau747) and test the output voltage of my charger,,and they are all good,.any solution to...
Eventually the problem was internal hardware, the charging terminals has a problem and that's why you getting this error on your unit while you try to charge your cellphone,
You have an alternative to use a desktop charger in able to charge the battery, or you may bring the unit for repair.
Hope this helps
Sep 01, 2009 | Nokia 5310 Cellular Phone
5310 not charging? can anyone give repair picture
Try replacing the battery. Also, check the power adapter make sure your getting electricity from it.
Unlocked Nokia 5310 doesn't turn on. I just gave up my iPhone (got a blackberry from work) and started using this phone again. Worked fine the first day; the next morning I noticed the battery was dead. It...
Maybe its your battery or charger port.Try to use another battery, if did'nt work then it's charger port.To avoid this kind of error please do not overcharged your phone.
Aug 02, 2009 | Nokia 5310 Cellular Phone
NOKIA 5310 can't turn on
Did you replace battery recently? Sounds like it has bad or wrong battery. If not, it is just dead.
To fix:
Power up phone on charger
While it is ON, pull the battery
Leave out for 1/2 to 3hr - phone still plugged in
Replace Battery, phone will power cycle and start charging
Leave plugged into charger 10-14hrs
Should be good now
Mar 26, 2009 | Nokia 6500 Slide Cellular Phone
Nokia charge without battery (Nokia 5310 XpressMusic)
no,charger provides only battery charging and it does not provide the potential difference for the phone to switch on.try with battery of your friends or some one else
Mar 11, 2009 | Nokia 5310 Cellular Phone
Nokia 5310 Cellular Phone Logo
50 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
