Question about Nokia N95 Cellular Phone
Profile automatic selected headset, I want to active general
I have Nokia N95 China, problem is "on profile headset is selected" I need to activate General, but I am not be able to select any other profile.
  • Nokia Master
  • 4,737 Answers
Remove the Headset (if any). Switch off your phone, remove the battery and reinsert the sim card, again reinstall the battery and Turn On your handset, now try changing the profile. If there's no software or hardware problem, you'll be able to change your profile now.
There's another simple method, turn off the handset and remove the sim card and switch on again, your phone's profile will change to "Offline". Switch it off, reinsert the sim card and try again.
Your last chance to do manually is to reset the phone to Factory Default using the security code [for original nokia the default security code is 12345 but for most chinese mobile it's 1122 or 3344 or 1234 etc.]
Good luck.
Thanks for using FixYa.
Posted on Jul 30, 2010
  • 83 Answers
Please try to reset yor phone to a factory settings.
Thanks
How to activate the gprs of nokia 1616
it depends on your carrier for Sun Cellular
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text "ACTIVATE" and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: "Sun GPRS"
APN: "wap"
Select SUN MMS
Account Name: "Sun MMS"
APN: "mms"
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: "Sun MMS"
Homepage: "'http://www.mmscenter.suncellular.com.ph"
Data Account: "Sun MMS"
Connection Type: "HTTP"
Proxy Address: "202.138.159.078"
Proxy Port: "8080"
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select "Sun WAP", Select "Edit Profile"
Rename Profile: "Sun WAP"
Homepage: "http://www.suncellular.com.ph"
Data Account: "Sun GPRS"
Connection Type: Select "HTTP"
Proxy Port: "8080"
Mar 07, 2011 | GPS
What is the format code for micromax q75 mobile actually in profile setting showing only customize not showing activate menu and activated only headst profile i tried to change profile but when i tried to...
to change the profile first dial the code *#84666*# then u vl reciv d menu of Factory mode. nw insert yr handsfree in fon first then go to the no.14 item "Headset" & press 'On'. thus u can check yr headset that its working. after that just easily pull out yr handsfree and u vl got the General profile simply.
I tested on my fon vn i stuck by this prblm
for further help u can ask me
Sep 26, 2010 | Cell Phones
How to activate gprs china phone
Text “ACTIVATE” and send to 2300
Select Sun GPRS
Account Name: “Sun GPRS”
APN: “wap”
Select SUN MMS
Account Name: “Sun MMS”
APN: “mms”
Jun 06, 2010 | Nokia E66 Smartphone
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
How do I take silent off ny nokia tracfone?
Go to menu and select PROFILE.Scroll down the list and select the profile you want either loud or silent or general and select it and activate it.If you want to make any changes in that profile you will have an option to PERSONALIZE it once you select the profile.If not just ACTIVATE the particular profile.
Nov 25, 2009 | Motorola Mobility TracFone® V170 Cellular...
The vibrate doesnt work
This phone vibrater is somewhat weaker then in other Nokia models.
If you checked your profile (The profile you have activated) to see if the vibrater mode is ACTIVE and if it simply doesn't work then you need to repair it.
All is/should be checked in the profile you have activated at a time..
May 02, 2009 | Nokia N95 Cellular Phone
How can i activate GPRS and MMS setting for my china mobile phone
hi there,
here i post some procedures you can follow for activation your GPRS and MMS.
Setup/Enable GPRS
Select Sun GPRS
APN: “wap”
Select SUN MMS
APN: “mms”
Setup/Enable MMS
Rename Profile: “Sun MMS”
Homepage: “’http://www.mmscenter.suncellular.com.ph”
Data Account: “Sun MMS”
Connection Type: “HTTP”
Proxy Address: “202.138.159.078”
Proxy Port: “8080”
Setup/Enable WAP
Select “Sun WAP”, Select “Edit Profile”
Rename Profile: “Sun WAP”
Homepage: “http://www.suncellular.com.ph”
Data Account: “Sun GPRS”
Connection Type: Select “HTTP”
Proxy Port: “8080”
hope it will help you to solved your problem or still you have any question regarding on it that you can't understand you can go on this site and log on.
http://www.kokeytechnology.com/gadgets/cell-phonesmobile-phones/how-to-activate-gprs-and-mms-of-nokia-phones-powered-by-sun-cellular/
Feb 16, 2009 | Nokia 6300 Cellular Phone
110i/1112 Nokia cant activate headset option
generally wen you insert the headset pin it goes automatically to headset profile, if this is not working then go bak to the vendor & get the phones software changed
Oct 13, 2008 | Nokia 1100
Uninstalled functions
i hear alot of problems bout these china phones. If i were you, i'd dump that junk and switch.
Jul 16, 2008 | Nokia N95 Cellular Phone
No ringtone on nokia 6300
hi envie & Anaagenius go to the main menu >setting >phone settings > restore phone settings  >code 12345 or dial *7370# then reinsrt sim & try (but before doing it take ur memory card out of the handset) ,if u still face any problem then dial *7780# but before doing it plz take back up of ur phone coz through it u may lose ur data of ur phone
Sep 18, 2007 | Nokia 6300 Cellular Phone
Nokia N95 Cellular Phone Logo
301 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
