Question about Intex Easy Set Pool 15x36
I have the 12'x30" Intex Easy Set pool, and there is water leaking from the bottom of the pump, Ive tried to figure out why but i cant find the problem...any suggestions?
    Problem Solver:
  • 15 Answers
YOU MIGHT CHECK THE GASKET INSIDE THE IMPELLR CASING AND MAKE SURE THE SCREWS THAT HOLD IT IN PLACE ARE TIGHT ALSO CHECK YOUR SEAL BETWEEN YOUR PUMP AND FILTER. THERE IS ALSO A LARRGE NUT UNDER THE FILTER HOUSING THAT COULD WORK LOOSE. I WOULD ALSO CHECK ALL O RINGS AND MAKE SURE THEY ARE PLIABLE AND IN GOOD SHAPE.
Posted on Jul 30, 2010
My 14' pool is leaking from the bottom slowly. 1" per 26hrs. I can not find a hole. No water on the sides of the pool. It is leaking out from under it. How do I find the hole. I have patched holes...
Using goggles I inspect the bottom and looking at each individual speck on the bottom. Sometimes what looks like debris is actually a hole though it seems it would take a good size hole to leak that much. Check the seam by gently trying to spread it.
Jun 14, 2011 | Intex Easy Set Pool 15x36
Air ring leaking on 18 foot pool....cant find leak...if it is the seam how do i fix it???
To be honest, ive seen 20-30 customers come to my company looking to fix this same problem. Weve tried vinyl patch after vinyl patch, and several different cement fixes. Nothing works.
The best results ive had are with a simple vinyl liner repair kit.
The most important thing is to let it sit for 48 hours before reinflating, but even this fix was only temporary.
Long story short, you get what you pay for, and intex is the cheapest pool systems on the market for a reason. The air ring always starts to leak right after the warranties are up, and the Intex company just plain out doesnt care.
Wish I had better news.
Mar 29, 2011 | Intex Easy Set Pool 15x36
I have the 18 ft x 48" intex easy set infletable pool and it has been set up for almost 1 month. Until a couple days ago I had no problems. In the morning I noticed the water level was down more than a...
This should be easy ... a foot of water? I would suggest you are leaking out the bottom. do you have a mask and snorkel? Watch the bottom from a floating position ... you might find the hole ... there are underwater patch kits for this very purpose.
Aug 24, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
Brand new filter pump leaking
If it is brand new and leaking, it sounds like your pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Jul 16, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
I had boughten a intex pool from a garage sale and the pool is fine but the filter is leaking water everywhere and all the water that is in the pool keeps coming out.
if it has hose clamps tighten them if the area that is leaking has o rings (they can become brittle and leak water) you can purchase them at local harware store
If it is a cracked housing they can be purchased at intex.com
call them up and order your parts
Jul 12, 2009 | Intex 15' X 42" Easy Set Pool Complete...
I have a intex pool
go to intex.com and watch the video
Water filter leak
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
Jun 26, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Leaky pump
There are rubber gaskets inside that get old and need to be replaced. Thats probably why it's leaking........Thank You For Using FixYa.Com! : )
Jun 17, 2009 | Intex Easy Set 2500 Gph Filter Swimming...
Water loss in pool, but no hole in liner
The only problem is that ther is a leak in the liner. Generally at the bottom where a rock or debris has made a small hole. They can be patched but the pool will need to be drained. Call your local pool service company.
Kurt
Mar 23, 2009 | Intex Frame Set 12 ft x 30 in Pool with...
Intex Easy Set Pool 15x36 Logo
199 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
