Question about Lenovo N200 T2310 Notebook
Once water fell down on my laptop. now my laptop keys are not working. what i have to do?tell me the trouble shooting steps.
  • Lenovo Master
  • 17,130 Answers
Only if you are lucky the fault will be resolved because if any water falls on electronics it would conduct very easily and hence the possibility that some damage has already been done. But to make an attempt we can first of all remove off the battery and remove the covers very carefully. remove the keyboards and look at the connecting cords to the mainboard. Use a good volatile solvent like petrol dipped in cotton buds to wipe out all the dirt+moisture inthe board. Use a hairdryer to warm off all the moisture and keep for drying at least for a day .Repeat the work once again before you reset the boards back connecting carefully. Now lets hope that your keyboard works or else the next option will be to connect a bluetooth wireless keyboard. Hope you try this out. Good day
Posted on Jul 30, 2010
The incline is stuck in the highest position
Try recalibrate. If that dont work, replace the incline motor.
  1. Press speed^ and stop simultaneously
  2. Insert key
  3. Press stop once
  4. Press Incline up
  5. (This should recalibrate incline). If this fails, replace the incline motor.
Dec 31, 2013 | Proform Perspective Es Treadmill PFTL99806
Asus Laptop Touchpad trouble shooting
Step 1:
Touchpad Not Working in Laptop b> Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Feb 06, 2013 | ASUS Computers & Internet
Turnon wireless
You have to hold the FN (function) key while pressing F12, that should work.
Jun 19, 2012 | HP Computers & Internet
Sahara n3156 network driver
In order for me to trouble shoot your issue I am going to have to see your System Information
If you do not know to find and tell me your system information follow the steps that I will give you to locate it.
Steps
Windows XP and Vista
  1. Click "Start" on the Taskbar
  2. Go to "All Programs".
  3. Go to "Accessories".
  4. Go to "System Tools".
  5. Click "System Information".
Windows 7
  1. Click "Start" on the Taskbar.
  2. Click on Control Panel.
  3. Click on System.
Once you have located the System Information, you will have to copy and pate it into the response box, so I can be of further assistance. I should have the Network driver for you in no time, and you will be able to be on the internet once again.
Thank you for your assistance
Mar 16, 2011 | Computers & Internet
The boiler wont fire up and the blue light flashes once per second
Let's see what we can do to trouble-shoot this boiler--
First of all-- Are we talking about a Hot Water 'Boiler'-- In other words does this boiler heat water that circulates thru the house, to keep you warm?
Next-- What is your fuel?
Have you Shut the system down, to reset it?-- What happens when it comes back on again?-- Clicking sounds-- pumps trying to start-- solenoids trying to open, etc.-- Tell us what you observe-- so we can help you trouble shoot this problem.
Mack B
Jan 15, 2011 | Heating & Cooling
1995 toyo camary that runs like hell
Several things can cause this. 1. Your engine is overheating because it is low on Coolant or Oil. 2. Your water pump is not working correctly and the engine is overheating. 3. You have stuck valves or blown head gasket. 4. Your block or Head is cracked. 5. Your Thermostat is stuck. Each of these has it's own trouble shooting steps and repair procedure. I recommend you get the Haynes repair manual for your make and model of vehicle to get a good reference for the trouble shooting and repair you will be doing. It has diagrams, step by step instructions and pictures of the repairs you'll be doing as well as testing procedures. You can get this from Auto Zone or just about any Auto parts store.
Dec 12, 2009 | 1997 Dodge Ram 1500 Club Cab
My Acer Aspire ONE has trouble shooting. I have the software for boosting it from a flash memory, but I dont remember the procedure
Step 1 - Download and install the Windows based HP USB Disk Format Tool. For your convenience, you can download it from HERE.
Step 2 - Download the Windows 98 system files from HERE. This is a zip file that contains all of the system files that you will need. Create a new folder and extract these files into the folder that you just created. Make sure that you preserve the directory structure.
Step 3 - Insert the USB Memory Key into the USB port of your computer.
NOTE: Make sure that the lock/unlock switch (if present) is set to the unlock position. USB MEM KEY 1
Step 4 - Launch the HP format tool program.
Under the device drop down list, make sure that the USB memory key is selected. USB MEM KEY 2 Step 5 - Under the file system drop down list, select FAT32. This is important to do correctly. USB MEM KEY 3
Step 6 - Check the box next to Create a DOS startup disk.
Select "using DOS system files located at:
Then click on the square box with 3 dots on it. USB MEM KEY 4 Step 7 - Browse to the folder that you extracted the Win98 system files and then click on the OK button. USB MEM KEY 5 Step 8 - Now click the Start button. USB MEM KEY 6 Step 9 - You will receive a warning message. Make sure you have the USB memory key selected. If you are sure, then click the Yes button. USB MEM KEY 7
Step 10 - Your USB memory key is now being formated and the DOS system files will be copied onto it.
Once the program has completed the operation, click on the Close button.
You now have a bootable USB memory key. USB MEM KEY 8 On the USB memory key, you will see these files. These are the basic Win98 system files. USB MEM KEY 9
Aug 29, 2009 | Acer Aspire One PC Notebook
Trouble shooting help
hello rosaura first tell me what kind of problems are you having with your printer???? i could probally help you how ever i need to know what the machine is doing?, brother tech
Jan 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
My Compaq Presario 1700 laptop gets hot and shuts off.
In most cases it is cause by the fan not supplying enough air.The first trouble shooting step is to verify if the fan is working properly.
Jan 01, 2009 | Compaq Presario 1700 Notebook
No sound!!
Does your laptop have a "hot key" for speaker mute?
On mine it is FN+ESC.
Apr 12, 2008 | Acer Aspire 3000 Notebook
Lenovo N200 T2310 Notebook Logo
93 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
