Question about ASUS P4GE-MX Motherboard
Can not detect devices from USB ports - ASUS P4GE-MX Motherboard
    President:
  • 2,351 Answers
Enter the bios by pressing the delete key every 2 seconds at boot up. Open your manual to page, 2-17. Section 2.4.2 Intergrated Peripherals. Find, USB 2.0 Controller and make sure it is set to [Enabled]. Save and exit the bios. Your system will auto restart.
Your USB ports should be working after windows loads. Play it safe and check windows for software and hardware updates.
Cheers'
Mike
Posted on Jul 30, 2010
My bios can not detect usb configuration why? my usb ports can not be Used?
If the BIOS cannot detect any USB ports then this laptop cannot have an USB port as a boot device, because the firmware BIOS does not support this.
The USB port is useable only when Windows is up and running when the USB driver is operating.
Apr 22, 2013 | Computers & Internet
DR-9080c Isn't being detected via USB
Uninstall the device driver, restart the Comp and reinstall the software. If the scanner is not detected, try inserting any working device on the same USB port. if it detected, thee could be problem in the Scanner, if the new device is not detected, then it may be port problem.
S. Mohan, India
Feb 07, 2013 | Canon DR-9080C Path-Through Scanner
My USB Ports don't work. Is this just a plug and play to replace or do I need to purchase a new CPU.
is it only one or all usb ports that doesn't work. Check your device manager and see if the Usb device are still working or the computer is able to detect it. If it is, and is able to detect and display your Usb ports then they should be working alright. There has been a virus that been going on lately that cause the computer not to read device detected to the usb ports since I had this same promblem before and it wasn't a hardware issue, but a viral issue. Had to run the latest definition and then formated my laptop to factory default.
Jan 14, 2011 | Gateway GT5404 PC Desktop
My laptop XP is not detecting Transcend StoreJet 25 External HD 500GB, but in desktop XP it is very well detecting and working. Pls let me know the solution for my laptop
USB devices draw electrical power through the USB cable.
Sometimes, the power-output from a USB port on a laptop is _less_ than that of a USB port on a desktop computer.
Hence, there are "Y" cables -- connect to two USB ports on your computer, and to the USB device at the other end, to draw more current.
Which manufacturer of laptop?
Which model-number?
Which Operating System?
Do other USB devices work when connected to the laptop's USB ports?
Nov 09, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
USB not working
if the usb detects other devices and not your drive,the drive itself may be faulty.If you plug in other devices in the usb and it detects them the usb drive or its connector is most likely bad.If it won't detect any devices the port is bad and drivers won't help.Possibly a motherboard issue.
Oct 09, 2009 | HP Compaq nx5000 Notebook
My computer cannot detect usb my computer model is 6bxa-61 samsung
You were saying that your computer could not detect any USB devices? Or just one USB device? Alright, you need to isolate the problem, follow the steps below:
1. Use at least 3 USB devices and connect them one at a time to the USB ports of your computer. If the first USB device is not detected, mark the USB port on your computer with "X" mark.
2. Now, connect the same USB device to another USB port of the computer. If you get the same problem, use the second USB device and connect it to the computer. If all 3 USB devices are getting the same problem connecting in all the USB ports of the computer (either on the front or on the back of the computer), then you need to update or re-install the USB driver to your computer.
3. Contact the manufacturer if the computer or the board and see if they could provide a USB driver for *********** board. Tell them what operating system (OS) you are currently running.
Have a great day!
Jul 24, 2009 | Computers & Internet
My pc won't detect my printer, my printer is brother dcp 150-c
have you connected the printer's USB port to your CPU? If not, then do so. If after doing it, still your PC don't detect your printer, make sure you have a functional USB port. To check it, try using a USB Flash drive if it works with your PC. If it won't, you might have to "Enable" your USB at your BIOS.
Regards!
Jul 09, 2009 | Office Equipment & Supplies
Windows is not detecting usb mouse and mouse is not working
which OS you have..? xp/2000 , both OS not need USB driver but auto detecting.., i request you to try another usb socket.
Jun 28, 2009 | Lenovo IdeaPad S10-1211U Netbook
MY PENDRIVE IS NOT GETTING DETECTED
hi im josh in cebu phils. friend if not detected the problem is you usb port or the flash disk. if you tried using your flash disk in other computer and you are sure that it is functional. then go to your usb port.check the connections.check also the confg.from the device manger if the printer port works. then dont forget that windows 98 and older versions of windows dnt automatcaly detect usb.good luck .
Feb 20, 2009 | Intel Motherboard
My usb port being not detected
Try downloading usb 2.0 drivers from microsoft.
Also look for drivers for your usb device..
check in device manager under usb devices and see if there is any yellow exclamation points next to any devices.
If that doesn't work your only option is to get a PCMCIA card that does USB 2.0
Jan 19, 2009 | Acer Aspire 3000 Notebook
ASUS P4GE-MX Motherboard Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
