Question about GE Spacemaker JVM1640SJ Microwave Oven
XL1800 GE Spacemaker Microwave oven "dead"
My son was using the oven as a timer with nothing inside. After 15 minutes it went dead. We replaced the fuse but it is still dead. Nothing, nada. Any advise? Thanks! Annamarie
  • 5,911 Answers
It's not good to run ANY microwave with the oven cavity empty. The items you place inside to cook or heat up act as a "load" and help to absorb/dissipate some of the RF energy. Your microwave has several thermstats installed that will blow in an overtemp condition. If you're lucky the Magnetron is still intact and only a thermostat has failed. The thermostats are small cylindrical devices mounted near the magentron and the oven cavity. They act as fuses and must be reset if blown. Go to geappliances.com and select "Parts & Accessories". Go the bottom of the next page and type in your model number. On the Search menu page select the second menu and type in "thermostat". There will be a series of thermostats listed with helpful drawings on where to locate them. I would advise you to check these drawings first and see if you can locate the thermstats to determine if they are bad. The thermostat should read a short (or very low resistance) if it is good. The part numbers are as follows:
Duct Thermostat (Item 27) ----------WB27X10714
Plate Thermostat (Item 115) ------- WB27X10713
Bi-Metal Thermostat (Item 110)-----WB27X10788
They all cost about $15.00 a piece.
Some additional advice: Make sure you unplug the microwave before servicing. If you are not savvy when it comes to electronics, or have never worked on a microwave before, it may not be adviseable to work on this yourself. Voltage potentials inside the High Voltage section of a microwave oven (where the Magentron is located) can be dangerous. There is a large capacitor that can store a charge and can be a shock hazard.
I hope this isn't discouraging to you, I just wanted to make you aware of some of the possible hazards associated with this appliance. I hope you find information helpful, and let me know if you need further assistance.
PS The alternative if all the thermostats are good, would be to check and/or replace the magnetron. (Item 73, Part #WB27X10305 at $115.00)
Posted on Apr 24, 2008
I have a GE Sapcemaker XL1800. Last night when I went to push express cook for one minute all I got was a small roar and after the one minute was done, my sandwich was not heated. We tried it several more...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
When I start my microwave, the timer runs but the
Hi,,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
In model spacemaker xl1800 no heating but all
heatman101
gfj
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave completely died because it was on with nothing inside it. Is there a fuse or reset button? Spacemaker XL1800
you could try unplugging it for about 10 minutes. this may or may not work as you may have caused some damage to the internal parts.
Oct 21, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
158 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
